well it's a 30c 1300mAh so that could still be too much. I just don't know. I hate to have to wait but I might have to wait until my new equiptment comes to run it.
I was taking a look at the Rio Ep and I was wondering if anyone has worked out how to get into the waterproof compartment without damaging anything? That is besides just using the removeable clear cover.
I withdrawl my question. You can get to anything through the opening the clear plastic piece covers. Just in case anyone else would wonder.
Hyrule in my post "Rio my thoughts" I mentioned that I tried this boat first with a 2cell lipo and then I ran a 3cell 3000mah 30C. This woke the Rio up. I ran the boat for about ten minutes and everything was still fine. I plan on running this boat with a three cell until something smokes, but I think this esc can handle 11.v no problem. This is my opinion.
Use clear electrical tape on the hatch and it will seal up all real nice
I havent as I have a deans connector on the battery and the boat has those white clip connectors. i have to find a spare male deans to install before i can do that. I did however find an old battery that will work.
So, I was looking at the motor and the size of that area. I was wondering if a motor mount that the brushless motor physically screws into is going to be neccessary because of the increase of power. Since, the stock motor only has a bracket that goes over top of the motor does anyone have any suggestions of a mount that would fit?
So far as I can figure, the holes are about 50mm apart.
Also, I was wondering if 2.85 per cell is too low of a voltage cut off. I'm asking because an ESC I found allows you to choose the cutoff voltage and they allow you to choose between 2.6/2.85/3.1V per cell.
The stock mount should work just fine with a 540 can..
and the lipo cut off, I would stay with the 3.1v setting and no lower.. IMO
As long as your motor is at a minimum 36mm in circumference it will mount using the stock parts. My brushless is 36mm and would not fit snug in the stock mount. I had to take the cooling coil sleeve and slide that onto my brushless and then into the mount and it snugged up perfect. I then took the cooling coil and carefully tightened it so that it would fit onto the brushless motor. I posted pictures on the "Brushless soon thread"
