Revolt 30 motor mount question
  • Aclinml
    • Jan 2015
    • 23
    OK, when I took the motor out these aluminum grommets came out also. Happened so fast, I was unsure which way the grommets go back in. does the wider end go in from the bottom or the top?
    Thanks again.......
    • 5660
    http://www.offshoreelectrics.com/pro...=dh-revolt-rtr
    Picture 5.....
    • Aclinml
      • Jan 2015
      • 23
      Kinda hard to tell, but it looks like they go in from the top.....
        • 5660
        What aluminum grommet are you referring? There are four "TRIM WASHERS" that sit on the wood, are those that you are talking about?
        • turbovr6jetta
          • Sep 2013
          • 83
          The "wide end" goes down towards the wood. That's why they all fell out when you lifted it up. They can be a tiny bit tricky to get back in. Cause they fall out easily
            • 5660
            What he said!
            My bad, I see how it is configured, thought was trim washer. Revolt 30 motor mount.jpg
            • Phoebe
              • Jul 2013
              • 43
              What he said!
              My bad, I see how it is configured, thought was trim washer. [ATTACH=CONFIG]127908[/ATTACH]
              Next time the motor is out, Dab a bit of RTV on each ferrule as you reinsert them into the rubber grommets. This way they'll stay in place until you want to pull them out.
              And while you're at it place a drop or two of CA in each hole of the motor mounting blocks, wait until it's thoroughly dry, and reinstall the motor mount screws. Your wooden mounts will last an eternity this way.
