Revolt stock motor shaft bent advice
  • Bking1340
    • 25
    Good day all
    I have recently ordered a Aquacraft Revolt 30 from Omnimodels.
    The problem I have is that there are a lot of up/down and sideway movement at the coupler/flex shaft – The movement can be seen when turning the prop by hand and the motor mounts are also moving around.
    I thought it was the aquacraft flex shaft or coupler, but I ordered a upgraded flex shaft and octura coupler from offshoreelctric (Received yesterday). The same problem.
    So this morning I installed my receiver and removed coupler/flex shaft from motor and gave it some throttle – When giving about 10% throttle, you can see that the motor shaft are wobbly/running off center.
    The alignment between motor and stuffing tube are 100% - the upgraded ose flex cable slides in like butter.
    Any advice?
  • high-tech
    • Sep 2013
    • 331
    Sounds like you got a bent shaft and if so time to replace the motor...
    Keith Geusic #677 NAMBA District 19 Seaducer Gas MONO, Aquacraft Revolt Fe30, 30in Max Cat scratch Built
      I do believe he has this taken care of: http://forums.offshoreelectrics.com/...tor-shaft-bent
      • Bking1340
        • 25
        Yes everything are good to go - just waiting for my replacement motor. OSE flex/octura coupler are waiting for the new motor. Have sharpened the rudder and rounded at bottom. Water pickup are bigger from the factory. I just need to balance and sharpen prop before maiden. Using EC5 connectors
