Completely Submerged Revolt 30, please advise
  • BHChieftain
    Fast Electric Addict
    • 2051
    I've had the AQ ESC under water several times and it survived-- it is highly water resistant.
    Chief
    • BHChieftain
      • 2051
      Originally posted by nammer View Post
      sweet thanks, do i spray wd 40 through the cooling lines? or right into the motor where the coils are, or both?
      No need to do anything with the cooling lines-- the job of the cooling lines are to pump pond water into the water jacket and cooling plates on the ESC.
      Your motor will work fine when dry, but using corrosion X can help extend the bearing life. I have an OPC tunnel with an exposed motor, so every time it capsizes it is under water (which is about every time I run it!).
      Chief
      PS, motor bearings can and should be replaced periodically
      • nammer
        • Nov 2013
        • 36
        update, came back from vacay, put everything back together, plugged in battery, looks good to go, thanks for everybody's help!
        AquaCraft Revolt 30
