Revolt Motor Upgrade
  • rickwess
    • Apr 2013
    • 777
    Originally posted by Mike Caruso
    I made a move to the next bigger M-645 and it runs great much more under control.
    WOW. The stock electronics can handle the m645?
    • martin
      • 2881
      Originally posted by Cinnabun View Post
      I run a 3674 with an m545 currently...
      I am beyond the limits of the hull. Full throttle is barely touched. The boat torque rolls and will barrel roll easily if you get into it too quickly.
      the 3674 is getting put into another project, so the revolt got a 4082 2000kv I've had laying around. I know it's going to be overkill.. but I put that in to atleast be able to run it.
      I'm currently looking at my options in the 36-41 range. I've been thinking about a vanquish.. still doing some reading.
      If your thinking of going for a Vanquish your better off getting the Osprey,their problems with the Vanquish quality ie to thin fibre glass with distortions in the hull (bad hook ) which affects performance quite badly. The Osprey is the same hull as the Vanquish but better quality, theirs a few on this forum that tried the Vanquish & found out these problems & got rid of the hull & replaced it with the Osprey which run much better.
      • 4sdash
        • Sep 2013
        • 54
        i have the same setup as cinnabun but with an x445 its a very fun boat in my opinion but very close to the limits of the boat get you cg wrong and you fishing for it
