External BEC Useful in Revolt?
  • skeeler
    • Jul 2007
    • 198
    Does the Revolt 30 benefit from an external BEC (voltage regulator), such as the Castle? Is the BEC in the ESC capable of supplying enough voltage and current to the rudder servo at full throttle? On an more general note, is there a rule of thumb for when an external BEC is necessary or helpful?
    Thanks.
    Revolt 30, River Jet, Southampton Tug, Outcast 6S BLX, 8ight-E, Ten-SCBE, 22 2.0.
    '09 Miata.
    Ibanez basses and guitars. Mapex drums, Zildjian cymbals.
    • 7277
    No benefit over the stock ESC...
    • BHChieftain
      Fast Electric Addict
      • 1964
      A friend of mine runs an external RX pack vs. using the internal BEC to reduce the stress on the ESC. I also run an external RX pack on one of my racing boats (OPC Tunnel, has a high stress load on the servo) that uses the UL1 + 60A ESC. If you are not seeing glitching and if the ESC is not running hot I would not bother changing it.
      Chief
      • martin
        • 2869
        Whether a particular esc set up has a built in bec & works fine it will be under less stress using a separate rx power supply, for me personally any thing that helps reduce stress on the esc is a good thing. Separate LiFe packs are so light the extra weight is not a factor at all.
        • skeeler
          • Jul 2007
          • 198
          What capacity (mAh rating) of LiFe battery do you use, and where do you get them?
          '09 Miata.
          • martin
            • 2869
            Im in the UK so get the LiFe batteries their, I use 2s 1000mah. I know some on this forum use 850mah & they get more than a days racing out of them.
