Silicone (Acidic/non-acidic) vs Goop
  • metoo
    • May 2013
    • 32
    I was about to head out to buy some silicone to seal the brackets on the back of the boat. I've read to get non-acidic silicone. Why is that? I was thinking of using Amazing Goop, since I have it. It's does have a quite a smell.
    Revolt 30, Octura M545, Spectrum DX3S tx, ORX rx, Shaft from Kinetic...not on the water yet.
  • Heaving Earth
    • 1877
    Uhm, why not use plumbers putty. It doesn't dry out and isn't permanent. I always stay away from silicone, especially if it ever needs paint. Fisheye galore
    • JimClark
      • 5902
      All my holes do not have any slop in them. I just make sure to seal them after drilling with thinned epoxy and have never worried about sealing them
      Billy Graham
      • Chilli
        • 3067
        I've used them all. Silicon, Goop, 3m 5200. I think even bathroom caulk. They all work fine. I bed down the hardware for waterproofing and to help hold it in place if the mounting screws loosen a little.
        Mike Chirillo
        www.capitolrcmodelboats.com
        • BHChieftain
          Fast Electric Addict
          • 1964
          I use Shoe Goo. I've been told that silicon sealant makes repainting very difficult.
          Chief
          • JrValente
            • 105
            3m 5200. Is made for sealing below waterline and is a polyurethane base so it will paint up. It is not cheap though.
            • Cooper
              • 1137
              I've always used 100% silicon as a seal on hardware. Spread a little on and whipe any excess off after installation. But as mentioned above almost all will work. 3m also makes a rubber tape very similar to plumbers putty, it holds together a bit and is tough to get screws through but ,makes a very good seal around threads if mounting holes are sloppy.
              • rickwess
                • Apr 2013
                • 777
                I use 3M Marine Silicon. Just a very thin bead around the mounting hole on the hardware. Never had it squeeze out. Not worried about re-painting since the proper prep work will take care of any residual silicon.
