got new boat any setup tips or help
  • rockford
    • Mar 2013
    • 116
    So i got a new revolt w/o a rx and as my first thread said im either going to put my 4pl controller in or a traxxas tqi with i have both so its not a money issue, anyways was wondering if there was any first steps in taking to prepare the boat for the water im fairly new into boats this is my first FE i had a traxxas nitro vee a fee years back and i have a traxxas villain ex now i ordered grim racer grease, prop balancer and some water proof tape but am also trying to find a good website on sharpening and balancing the prop also where to run the antenna
    miss geico 29,revolt 30,villain ex,summit,scte,8ight
    • 7512
    http://forums.offshoreelectrics.com/...t-Mono-Q-amp-A
    Lots of good reading here.
    • Heaving Earth
      • 1929
      just make the antenna come up thru the hull, doesnt really matter where, its wherever suits your setup best. sharpening the prop is def a good idea as doby posted a link. also electrical tape is waterproof and cheap, or renfrew hockey tape also, and its clear.
        If I run an antenna,
        I like to make it look scale for the boat.
        Like it belongs there,
        Some have two antenna wires and one wire go's forward in the hull toward the bow,
        The other go's through the deck or hatch.
        You can make a hole for it and add a boot over the antenna than seal it in place,
        With ca and silicone.
        As for the boat,
        Check over everything in it for loose screws water flow and do water tight test.
        Look for leaks in the hull, It may come in at the hardware or up the stuffing tube.
        When you ready to run it, Just run it for a minute or two and bring it in and check for water in the hull and also temps on everything.
        Also watch the tape because it may pull the paint off the hull.
        • rockford
          • Mar 2013
          • 116
          Thats a good thought on the tape pealing the paint, I thought maybe I could put a piece of tape down and when I tape the hatch I could tape over the first piece and try to peel the second layer off and just leave the first layer on all the time. I I did let it sit in my tub for an hour obviously it wasn't moving so its not a true leak test but the best I can do now until I get my new esc from Aquacraft as posted it another thread
          • Heaving Earth
            • 1929
            I've never heard of the tape peeling the paint on these hulls
            • BHChieftain
              Fast Electric Addict
              • 2051
              Be sure to read up on safety when sharpening/balancing beryllium copper props-- the particulate form is extremely dangerous so you need proper respirators and a safe way to deal with the dust (like a hood).
              Chief
              • rockford
                • Mar 2013
                • 116
                Chief
                i think i may do it outside or at work i work at a ford dealer and we have vents in the floor for exhaust fumes. is there any good link on how to sharpen and balance them properly for a first timer?
                • iridebikes247
                  • 1669
                  Easy to do but definitely take your time.
                  • rockford
                    • Mar 2013
                    • 116
                    Originally posted by iridebikes247 View Post
                    http://www.youtube.com/watch?v=OtEIhWQtxVo
                    going to have to get some small files from the tool guy tomorrow or home depot
