Revolt on one 3S?
  • Casey
    • Jan 2012
    • 36
    Revolt on one 3S?
    I just picked up a Revolt and wondering if it will run safely on a single 3S 40C Lipo Pack? wanting to slow it down a little for my son to drive. thanks
  • chipgibbs
    CG3
    • Aug 2012
    • 184
    It should run fine. You could also run 4s and trim the throttle.
    • capnswanny
      • Feb 2012
      • 867
      I don't think it will work on 3s with the stock ESC, I believe they are 4s only. Dialing down the throttle would slow it down if your TX has that capability, but you'd want to keep an eye on your temps as the ESC can heat up quickly when NOT running WOT.
      you could pick up a cheap hobby king ESC that works on 3s and use it for your son...should be able to get a Birdie for 20 to 30 bucks.
      This is NOT a toy?!?
      • Casey
        • Jan 2012
        • 36
        thanks for the info, i'll check it out. if not i have an extra aquastar 120 that i could run
        • BHChieftain
          Fast Electric Addict
          • 2051
          Or you could just prop the boat way down.
          Chief
          • Bduncan
            • Jan 2013
            • 296
            Revolt pretty slow on 3s. I run mine on 4 and 5s. For five s you need at least 120 amp esc. Here's is video 5s 42 55 grim.
            • Bduncan
              • Jan 2013
              • 296
              By the way I have run mine with stock esc on 3s. Not much excitement.
