Revolt gets Carbon
  • chipgibbs
    CG3
    • Aug 2012
    • 184
    Revolt gets Carbon
    While waiting on the cold to go away, I thought I'd make use of some carbon fiber by reinforcing the
    hull of my Revolt. This might add a little weight but, the hull has always seemed a bit flimsey.
    First I made paterns from paper & cut out the carbon cloth
    Next I sanded the hull interior with 120 grit and blew out the dust and wipped it with acetone
    Now for the speedy part. I brushed in some Z-poxy and layed in the carbon. Note that it is wraped up the sides of the motor mount bosses.
    Also note I have added a stuffing tube brace made of plywood and carbon fiber.
    And finally brushed more Z-poxy onto the carbon to fully saturate it. With an exacto knife I carefully fix any stray strands... Finished product looks pretty good
    CG3
  • Chilli
    • 3204
    Nice job Chip. One tip when I lay down CF is to use foam mini touch up rollers to go over the CF as a final step. This will soak up any excess epoxy and leave a nice finish. Rollers are also a little better at working in the epoxy without disturbing the cloth.
    Mike Chirillo
    www.capitolrcmodelboats.com
    • chipgibbs
      CG3
      • Aug 2012
      • 184
      Thanks Mike,
      I've used the rollers before, just not on boats. Another trick is to blot with toilet tissue. I built Hand launch gliders and DLGs for years and weight really counts so all the excess epoxy has to be removed.
      CG3
      • chipgibbs
        CG3
        • Aug 2012
        • 184
        Almost ready for water again with new Carbon & New Battery tray
        CG3
          That looks REALLY good!
          May I suggest that you do a range test since the Tactic receiver has no antenna and now you have CF in the hull. Most likely it is a non-issue since there isn't any on the side, but I have lost signal on Tactic before, thank goodness for Fail Safe.
          • chipgibbs
            CG3
            • Aug 2012
            • 184
            Thanks T
            I will change it over to Futaba as soon as I get another receiver.
            Tomorrow should be 50 degrees and the Revolt is ready
            • Chilli
              • 3204
              Take that NAMBA sticker off your boat too. LOL
              Where are you running tomorrow?? I've got a new Sport Hydro that needs maidening. Take advantage of the weather. The ponds might be hard by next weekend.
              Mike Chirillo
              • chipgibbs
                CG3
                • Aug 2012
                • 184
                Ive been running at Trinity park lake in Centreville. Its right off Hwy 29 just before 28 behind the
                Velocity 5 sports bar & copper canyon restaurant.
                • Chilli
                  • 3204
                  I returned your email. LMK if you head out there.
                  Mike Chirillo
                  • chipgibbs
                    CG3
                    • Aug 2012
                    • 184
                    Not too exciting, it was really windy and the Revolt blew over 4 times. You can hear the wind in the crummmy video.
                    • bob_t
                      • 159
                      So that is why he has his name and phone number inside the hull ... in case it gets away and won't come back?
                      • chipgibbs
                        CG3
                        • Aug 2012
                        • 184
                        The name & number in the boat is a carry over from RC planes....THey used to get away once in a while. BTW, no problem with the Tactic reciever today, just the wind.
                        CG3
                        • bob_t
                          • 159
                          I know what you mean with the planes (that's kinda what I was poking at, above). When I was a kid, I watched as one of my grandfather's planes flew out of sight, never to return ... and then again in college saw the same thing happen with a couple of friends' planes, too.
                          Looks like you have stock motor and esc .... what prop (in the video)?
                            CG3
                            Video looks great! I am so glad to hear that the tactic didn't pose a problem, truth be told, I had built a Mean machine 3 months ago, still didn't have time to maider her, but the CF bottom had me worried, now I can relax. Thanks!
                            • chipgibbs
                              CG3
                              • Aug 2012
                              • 184
                              Prop in the video is an Octura m545.
