Stock Revolt hit 46,7mph- 75,2kmh
  • gyrotron
    • 499
    Gio,
    I appreciate the trasom pics you posted. How much negative trim did you give the tabs? I have got mine at -2 degrees.
    Thx
    • chipgibbs
      CG3
      • Aug 2012
      • 184
      I've been reading this forum trying to get my Revolt into the high 40s & today it clocked 46.6 & 47.8 mph. I had to take pictures of the gps for proof. Of course Murphy says only the 46.6 picture is readable but I think you can make out the 47.8 if you try.
      The M545 prop is the one.
      • MAMBA2200
        I need a scooby snack
        • 1347
        great speed any vids whats your set up
        • littledvl
          • Apr 2012
          • 77
          ChipG[ATTACH=CONFIG]85968[/ATTACH][ATTACH=CONFIG]85969[/ATTACH]
          I saw it in person and it was running awesome. Got my m545 on the boat but a storm has seem to roll in so it may wait until tomorrow. Good to meet you guys today Chip, ill get my boat out there sometime soon with you guys.
          • MAMBA2200
            • 1347
            looks like the m545 is the prop for the revolt thats two boats in the high 40's both stock and both with m545 great runs from both of you guys
            • chipgibbs
              CG3
              • Aug 2012
              • 184
              Mamba, As far as set up, I adjusted the strut to neutral. Checked with a straight edge on the bottom of the hull. This puts the bottom of the strut almost 1/4" above the bottom of the hull. I have upgraded the flex shaft and collet with the OSE units. I have not touched the trim tabs or turn fins. The battery I used is a Hyperion 4s 4200, all the way back in the tray. Scuffed the bottom with 1000 grit. That's it....
              Great boat
              Chip
              Oh, and the M545 prop balanced & sharpened by me.
              • MAMBA2200
                • 1347
                very good run with it littledvl told me of your run today on another forum thats great info you should be proud of that speed my motor smoked the other day so im down till my new stuff gets here next week im still searching for speed myself 39.8 is my best run so far
                • Chilli
                  • 3204
                  Nice Job today Chip. Cool little GPS you had. Glad I didnt ask for you to put it in my sport hydro. LOL
                  I know you were going for top speed today but is your strut adjustable up and down? If so, dropping it a touch will get her settled in the water a little better.
                  Mike Chirillo
                  www.capitolrcmodelboats.com
                  • giobors
                    • 33
                    Hi guys
                    @girotron: I spent lot of time to totally eliminate Chime walk; the Key is both right trim tabs leveled at transom less 1mm or 2 depending by battery weight
                    Both left trim tabs same leveled 1mm less than right tabs.
                    Add 40g at the more external left side into the hull on the cog, the same of wheel cars,at this time my revolt auto shut off the chime walk if it engaged.
                    Hi Chipgibbs & Littledvl Nice to meet you on high 40's, yes m545 push very strong, if i can give you a suggest take a look at both ESC/motor temperature
                    Giorgio
                    • chipgibbs
                      CG3
                      • Aug 2012
                      • 184
                      Motor Temp
                      I ran at least 5 times today for 4 or 5 laps, or about 4 minutes. the only place I felt any heat was the battery connectors, and they really weren't that hot. Motor & ESC were barely warm.
                      Chip
                      • giobors
                        • 33
                        Chip
                        Finally my browser quote! Chip did you have any change on cooling circuit? or only you file water inlet?today i began check both temperature every run and no more of 45-47°celsius for the motor and every time -2 for ESC, i ran with grim 45/68
                        Giorgio
                        • giobors
                          • 33
                          Hi guys this is another video uploaded,i do it just for fun when i went on freetime with my family at sea.
                          Revolt can run not only on glass! i remember that i clock it 66.2Kmh- 41.1mph and there was a m445 prop, and i try but never more of 75-80% throttle.... penalty a swim
                          Hope you enjoy Giorgio
                          • chipgibbs
                            CG3
                            • Aug 2012
                            • 184
                            Cooling System, No Changes....
                            Chip
                            • gyrotron
                              • 499
                              Another great run Gio!
                              That boat is running like a charm. Beautiful waters man sparkling blue/green. Who would have thought you had those kind of waters over there. I have some Italian blood in me from the Maggiolo's side of the family but I have never been to Italy. I also have family in Cortina D'ampezzo. But me non posso parlare italiano... I am going to prepare a m545 propeller for my Revolt. I am curently running on a X642 and I really like this propeller but now I want to try the m545.
                              Buona Fortuna!
                              • giobors
                                • 33
                                Buona Fortuna!
                                Hi Girotron Thank you i'm happy you enjoy the video!
                                Italian blood and you never been in Italy? don't waste time, come on, Italy waiting you.
                                in Sardinia where i live, everywhere the sea water is like you've seen in the video,here upon 2008 there was an USA submarine base in La Maddalena, and this summer lot american was here for vacations, whenyou want come here you are welcome ps let me know i'll bring you on my boat ....opps I think i'm off topic sorry
