Adjusting the LVC on the RTR Revolt 30
  • Tom899
    • 91
    Is there any way to adjust the LVC? I believe it is set very low, about 3.00v. I know I should time my boat and bring it in but a few times I ended up stranded without much warning. A few friends with Proboat Mystics seem to have the luxury of bringing their boat in after they let it set for a minute whereas mine only leaves enough voltage for the steering servo but the motor won't budge. Again I realize I should bring it in before it gets to this point but in reality it always doesn't happen. If the included speed control is not adjustable can you please recommend an adjustable one I can replace it with? Or, maybe it's just me, my batteries, etc... Looking for guidence from more experienced than me. I don't mean to complain as I think this boat is awesome and can't think of another RTR I would rather have.
    Thanks,
    Tom
  • Tom899
    • 91
    Yes, you are correct about the LVC, default is 11.63v divide by 4 = 2.9075v per cell. Is this kind of low or normal?
    • Tom899
      • 91
      Originally posted by Billy Barnacle
      ...2.9075v per cell. Is this kind of low or normal?...
      Instructions I've read say not to go below 3.0v per cell. And none of the AQ ESC's are adjustable, for anything including voltage.
      If you would prefer an adjustable ESC, might I suggest a HobbyWing Seaking 90-amp unit?? Stocker is 60-amps and barely enough. I just downloaded the Revolt manual, under the motor specs section it states "Max. Surge Current: 80A/5 sec". And the stock ESC is 60-amps, hhmmm....
      Seems like a 90-amp ESC (or more) would be a much safer choice than the stock 60A, I attached the HW ESC manual to this message.
      FYI: default LVC = 3.2v/cell. JMHO
      Thank you for suggesting this ESC. I like it and it looks like it will do what I want.
      Tom
      • dana
        • Mar 2010
        • 3660
        If you end up stranded, you're going past the lvc. The lvc should cut you're power in half, which means its time to stop running and bring the boat in. Pay atttention to this. If its not cutting power in half and just stopping you probably have some other issue there.
          • 7512
          Nothing wrong with the stock controller...its been proven by many to handle way above the stated ratings. ESC's tend to be rated below what they can actually handle to help protect some people.
          • Tom899
            • 91
            Tom's original question was: is there a way to adjust the LVC on the Revolt's ESC. As we all know, the answer is no.
            That was my primary reason for suggesting the Hobbywing Seaking series, the other being personal experience with 2 of them.
            35-amp unit I put in my Rio when I first upgraded it to brushless, and the 60-amp unit I used with my AQ Wildcat EP.
            I set the timing on the 60-amp unit to 11.25-degrees for the same reasons I suggested. That subject has been brought up somewhere on this forum previously, think it was in the UL-1 section.
            If having adjustable LVC is an issue for Tom, then he will of course have to replace the stock ESC with an aftermarket unit. My replies & suggestions are based on personal experience. I still feel an upgrade is in order, but that's just my opinion. I don't want to risk starting a "pissing match", so I'll leave it at that.
            Tom, good luck with your endeavors no matter which way you choose to go.
            Regards,
            Thanks Billy and everyone else- I appreciate your advice and all the ESC information I can get.
            I'm a beginner with boats and Lipo's so all of you know more about this than me. The bootom line is i'm just looking for a better way of knowing when it's time to bring my boat in before I get stranded, which has happenned three times so far. My boat seems to hardly slow down and no warning before quiting. I have two sets of nano 5000mah 45c/90c with a Power Lab 6 charger controlled through my computer. I always balance charge and the batteries are in great shape. A few friends in the club have Pro Boat Mystics and if there boats should happen to quit, they let it sit for a minute or so and then they can then bring it in. Now I assumed this was because there LVC was set higher and still had the voltage to limp it in. So, again this is just my assumtion and beginners thinking so I'm certainly not dead set on needing an adjustable ESC just thought it might help? Maybe I should be looking at another solution.
            Thanks,
            Tom
            • dana
              • Mar 2010
              • 3660
              I dunno man, the studder bump feature always worked fine on all my aq escs. Always. I dunno what's going on with yours but, I guess go buy an aftermarket esc, then sell the factory one. Should have no problem selling it.
              • Tom899
                • 91
                Can you please explain how the studder bump works? I don't see anything happenning to mine, unless I don't know what to look for?
                Thanks,
                Tom
                • Grimracer
                  • 660
                  Dana,
                  Couple things...
                  1. I'm at AQ's website and have the Revolt manual on screen. On page 3 they have the motor & ESC specs and info on the subject of LVC.
                  First the motor specs = Max. Constant Current: 50A -- Max. Surge Current: 80A/5 sec. --- Now the ESC... Output Current: 60A continuous maximum -- 72A surge maximum. As you can see, in a surge situation the motor is capable of drawing more current than the ESC can deliver. The Revolt is not the only AQ boat that has that issue, they all do. The 60A ESC in the Revolt is also used in several other AQ boats, MC, UL-1 and others. The 45-amp ESC in the SV27's are also underated for the motor used them.
                  The 50-amp ESC that comes stock with the Wildcat EP is also underated for its motor, that was one the reasons I replaced it with a 60A Seaking unit out of the box.
                  The ESC in the Rio EP is notorious for frying when used with 8.4v batteries, AQ has a tech note on the Rio page but it's 200% pure BS!! as myself and countless other Rio owners have discovered. There are dozens upon dozens of posts on practically every forum on the net (not just this one) on that subject. The Hammer EP suffers the same problem because it uses the same ESC.
                  What that tells' me is: AQ are cheapskates more interested in profit than making a quality boat. Doesn't matter if it's a $160 entry level boat or a $350 FE.
                  2. AQ's LiPo ready ESC's have a feature called "stutter bump". On page 3 of the Revolt manual they discuss the subject of "stutter bump" & LVC. Here's what it says...
                  Notes about using LiPo batteries in your boat: The Revolt uses the AquaCraft 60amp motor controller. This controller has a built in stutter bump system that cycles the power to the motor when the battery voltage reaches 12V. This is designed to warn you of impending low battery voltage and subsequent shut down. It also has a 10.8V battery cut off safety system that shuts the power down to the motor to avoid damaging the batteries.
                  3. Somewhere on this forum there's great thread about boat ESC's, how to calculate what amp ESC you should use for your application and so on. In that thread various posters make statements such as: boat motors pull far more current than there car / truck counterparts, boat ESC's are often times over-rated (advertised 60A is really a 45~50A), allowing "overhead" and other really useful info. Part of the reason for allowing overhead is because of the false amp ratings. The figures I've seen are in the 20% ~ 30% range, I personally go with 30%.
                  Using the above Revolt specs with 30% overhead I find that I should have a ESC with a minimum of 65A continuous, which of course is 5-amps greater than the stock unit. And 104-amp surge - a whopping 32-amps more than the stock unit. That is why I suggested the 90-amp Seaking unit to Tom in my first reply.
                  Based on the above info, I maintain that the ONLY thing wrong with Tom's ESC is that it's cheap factory POS that needs to be replaced with a qualitiy aftermarket unit like the Seaking series.
                  Tom, should you decide to go with one of the Seaking units there's something I would like to point out. By default the motor timing is set at 15-degrees, AQ ESC's are set at 10-degrees. I ran a Seaking 60A unit in my Wildcat and took the timing down to 11.25-degrees because the next lowest setting is 7.50-degree's. Obviously 11.25 is a lot closer to 10 than 7.50.
                  Hope this extra info gets you pointed in the right direction.
                  Regards,
                  Aha yes.. I feel the love........
                  Grim
                  • dana
                    • Mar 2010
                    • 3660
                    Tom, there should be a noticeable studder in the motor operation when it kicks in. Surprising you havent noticed it.
                    Grim, i hear ya man. My escs have all worked flawlessly
                    • Tom899
                      • 91
                      Maybe it is working and I don't notice it? I love the boat and hardware, everyone watching me run is impressed. I'm just trying to maximize run time and bring it in before it quits. I've been successful recently by bringing it in after about 5 minutes, which is probably a little early, but it's no fun to be stuck out on the water with no wind or current to bring it in. If you guys tell me it is what it is and an adjustable ESC will be of no help than I will just live with bringing it in early. I still don't quite understand the studder bump, maybe my boat has been too far away for me to notice it? It seems to all of a sudden slow down and stop, all within under 10 seconds. I don't mean to start any disagreements, I'm in the learning mode and looking for advice more than anything. If there's a better way or new piece of hardware that might help I don't mind hearing about it.
                      Thanks,
                      Tom
                      • dana
                        • Mar 2010
                        • 3660
                        Without seeing it run it's hard to tell man. You can buy a seaking esc for cheap money that are adjustable. 5 minutes is a good run.
                          • 7512
                          Agreed, I guess the 6 AQ controllers I've been racing for the past 3 years must be the only good ones..aside from Dana's..
                          Electronics are UNDER-RATED...Period.
                          • Tom899
                            • 91
                            I think mine might be working perfectly also. Infact I'm sure there is nothing wrong with it and I never said there was, just was wondering if there is anything better on the market that might help my situation. In my case it could be me not fully understanding everything. Sorry if I opened up a can of worms, didn't mean to.
                            Thanks,
                            Tom
                            • Tom899
                              • 91
                              Good feedback Dana, I didn't know 5 minutes was a good run, so maybe I'll just stick with 5 minutes and be done with it.
                              Also, I had a great run last night by stacking my batteries in the middle instead of side by side, completely got rid of any chain walking and 42.4mph. So with this in mind my next battery will be a single 4s and i'll try another company. You know, maybe the characteristics of my nano batteries are not allowing the studder bump, maybe all of a sudden they drop fast? A different company battery should prove this out.
                              Thanks,
                              Tom
