Revolt 30 - Adjustable stuffing tube bracket
  • gyrotron
    • 499
    Hello,
    Is anyone out there using adjustable stuffing tube bracket on their Revolt? After what happened today on my boat I think is does need it. Since I will be replacing the brass tube I was wondering what you guys think about installing one of these brackets designed for the Motley Crew.
  • JimClark
    • 5913
    nothing a little wedge of wood and some fiberglass couldn't accomplish
    Billy Graham
    • gyrotron
      • 499
      I am new to this, I have not worked with FG before. Can you show me a sample pic? Thank you
      • wavekatcher
        • 38
        What happened to your boat to need to do this mod?
        Revolt 30, SuperMonoX, NQD "Tear Into"
        • gyrotron
          • 499
          I raised the strut +2mm looking for more speed and after a couple of runs, the brass tube was loose and bent at the section where it curbs up, it had moved forward towards the collet, the teflon liner kind of started to melt, the epoxy holding the tube against the transom started to crack...
          • JimClark
            • 5913
            here you go
            Billy Graham
            • gyrotron
              • 499
              Ok, I now know what I need to do. Thank you.
              • gyrotron
                • 499
                Originally posted by Mike Caruso
                Go to my Album Gallery you will see the same fix a small pc of wood I used a round file to make it fix under the tube. Then angle filed the bootom of the wood so it fix the floor just fine. Epoxy all done. Its the one with the Re Volt sitting in the White scale round nose hydro
                Thanks Mike.
                • gyrotron
                  • 499
                  Look real close and you will notice I have added wood from motor mount to motor mount. This ties them making one mount and also they DO NOT TOUCH THE HULL. Just like the two battery tray ends.
                  Yes I see it. What type of wood and wood thickness did you use?
                  • gyrotron
                    • 499
                    Whatever I had laying around maybe 5/16 x 1/2 I did use balsa. Hrad wood is stronger but I just wanted to have something under the end of the tube. Once coating with Epoxy I find it works fine. The motor mount pcs where Hobby shop 1/8 and 1/16 plywood. Again I had some leftovers that got put to use.
                    Less weight = more speed
                    Not that the little pc. used there would add any weight but always keep thinking about weight.
                    I designed this stuffing tube bracket. Holding the stuffing tube steady has been a problem on my boat. The bracket is made of 1/8" birch plywoood with a 1/4" intenal diameter rubber groomet (which absorbs the vibrations pretty well) and it has not been epoxied to the hull yet; the center line of the bracket is 1" away from tube end towards the motor. I am planning on wateproofing the plywood before applying epoxy. Does anyone know a good product for waterproofing plywood?
                    • dana
                      • Mar 2010
                      • 3660
                      Use epoxy or super glue. How much water will be in your hull anyways?
                      • gyrotron
                        • 499
                        Well, nothing on regular operation unless boat gets belly up... but for now I'll just coat it with some exterior grade water repellent spray I have found in my garage...
                        • gyrotron
                          • 499
                          Gents,
                          I have found this butch block shaft holder from an UK seller that would be great to add on our Revolts it is just a bit expensive though... here is the link and a pic:
                          http://www.ebay.com/itm/120762623883...84.m1423.l2649
                          I wish OSE had one of these for sale.
                          • h2o 1
                            • Sep 2011
                            • 854
                            gyrotron,did you ever get the butch block? Im thinking of using one of these on a hydro.Rocketcity racing has them with the grease fitting on top.What is that mandrel for by the screws? I've been wondering about that. Thanks,Mark
                            • gyrotron
                              • 499
                              No, never did
