Finally got my batteries, learned my powerlab 6 charger and ready to try her out! The long shipping time for my batteries was probably a good thing as this gave me time to balance and sharpen my prop, sharpen the rudder, elongate the water inlet hole, replace the stock shaft and collet nut with the one from OSE, add the thrust bearing, change all my connecters to EC5's, Loctite all the hardware, and read read read the forum for hints and adjustments. The boat ran great! It seems very fast and handles well. Not a single drop of water in the hull when finished. I did notice it chine walked at top speed. I have since raised my turn fins up, slightly lowered the inboard trim tabs and looking forward to see what that does. My batteries were all the way back so I will experiment with relocating those next time out. Awesome boat and very happy so far.
Revolt 30 maiden voyage last night
Hello Tom,Originally posted by Tom899 View PostFinally got my batteries, learned my powerlab 6 charger and ready to try her out! The long shipping time for my batteries was probably a good thing as this gave me time to balance and sharpen my prop, sharpen the rudder, elongate the water inlet hole, replace the stock shaft and collet nut with the one from OSE, add the thrust bearing, change all my connecters to EC5's, Loctite all the hardware, and read read read the forum for hints and adjustments. The boat ran great! It seems very fast and handles well. Not a single drop of water in the hull when finished. I did notice it chine walked at top speed. I have since raised my turn fins up, slightly lowered the inboard trim tabs and looking forward to see what that does. My batteries were all the way back so I will experiment with relocating those next time out. Awesome boat and very happy so far.
Did you have to use a spacer when adding the thrust bearing? When you do this upgrade do you have to tighten the collet all the way up againgt the bearing? I will be doin this same upgrade on my Revolt and wanted to make sure I install it correctly.
Thank you.Last edited by gyrotron; 08-11-2012, 01:25 AM.
I didn't have to use a spacer, I think because I also ordered the upgraded collet and nut which is longer than the original, it actually has two set screws to hold it on the shaft. I have it against the bearing but it's not preloaded which I think it should be. I may redo it as read another user mentioned he preloaded his by 1\2. I need more information on what is recommended?
Originally posted by gyrotron View PostHello Tom,
Did you have to use a specer when adding the thrust bearing? When you do this upgrade do you have to tighten the collet all the way up againgt the bearing? I will be doin this same upgrade on my Revolt and wanted to make sure I install it correctly.
Thank you.
I'll let you know what I find and you please let us know your experience?Originally posted by sturco View Posttom899, good for you ! I did exactly the same thing and have an excellent Revolt. Let me know how your "chine walking" adjustments work as this is my next set of adjustments. same set-up as you have w/o those adj's.
Steve
Thanks
It seems to me that the chine walk will greatly reduce by moving the batteries forward at the cost of speed. I think I can put up with some chine walk for higher speed. So far I'm really pleased with the boat, I especially like how well it turns at high speed.
Good to know you are getting some extra mph with the serviced stock prop. Let us know how the new trim tab setting went.Originally posted by Mike CarusoI ran yesterday 45 x 68 on glass smooth water no wind 44.7 mph 1000 watts ouch, sounded like more rpm and very little chine walk. Then I installed the stock prop that I finally sharped and balanced. The boat was about as fast as with the big prop. I forgot to bring my laptop so I could only save the first run. I telling you this is the prop you want. You can carve the water up, u turns and blast down the straightaway. My 4s is still back and I have it shimmed to the port / left side as it makes a difference. I have not lowered the trim tabs yet but I will just lower the starboard / right side outside one first, then second. This should help with the boats torque roll. I will bring the laptop next time as I leaving the stock prop on for now.
Update- I ran with my bike Garmin GPS today (2oz), max speed was 35.8mph. The boat is stock except I balanced and sharpened the prop, elongated the water inlet, sharpened the rudder. I'm running two 2s 5000mah 45c nano batteries. I do have a Octra x642 and Grim Racer 45x68 props but have not prepared them yet. I sure would like to break 40mph. What do you guys think I should do for mods to gain 4 or 5mph?Originally posted by Tom899 View PostIt seems to me that the chine walk will greatly reduce by moving the batteries forward at the cost of speed. I think I can put up with some chine walk for higher speed. So far I'm really pleased with the boat, I especially like how well it turns at high speed.
Nice Grim! I will start to prepare my L45x68. I would like to break 40mph (I'm at 35.8mph). Should I buy a particular battery / batteries? Are there any must do adjustments?
Thanks for your help,
Tom
Originally posted by Grimracer View PostThought you might enjoy
L45X68.. 5th run of the day. I dont usually show stuff like this but its good info to ponder.
[ATTACH=CONFIG]83583[/ATTACH]
GrimLast edited by Tom899; 09-01-2012, 08:09 PM.
Udate 2- I balanced and sharpened my Grim Racer 45x68 prop, installed it and ran 40.4mph (5mph increase over stock prop). This boat turns so sharp I think it's going to tip over but it doesn't! Very well designed.Originally posted by Tom899 View PostUpdate- I ran with my bike Garmin GPS today (2oz), max speed was 35.8mph. The boat is stock except I balanced and sharpened the prop, elongated the water inlet, sharpened the rudder. I'm running two 2s 5000mah 45c nano batteries. I do have a Octra x642 and Grim Racer 45x68 props but have not prepared them yet. I sure would like to break 40mph. What do you guys think I should do for mods to gain 4 or 5mph?
This run was with my batteries all the way back. Maybe some different batteries? Move to one 4s instead of two 2s? Although the weight is about the same, just concentrated lower and more middle.Originally posted by Mike CarusoThat's great news now move the batteries back. Slow the steering down or turn slower, you are correct it does come about !!!!!! Coolest boat Big fun. Mike
Hello Mike,Originally posted by Mike CarusoI have Grim 4s pack. Ran today something is going away in my boat. I have lost 8-10 mph I ran my Grim 4s pack, then 2x2s Hyperion 40c same performance as Grim and 2x2s Turnagy (not as strong batteries) I either have the motor which has lost some power (bearings + drive line OK) or the ESC is my problem. Really don't know what to do at this point? I can tell you the second to last run I finally adjusted the right trim tab level with the hull bottom. This did not slow the boat down but made it run almost perfect up right at WOT. The last run as I was tired and hot I turned the boat over and scuffed the bottom lightly with a 3M green pad (just the rear section) where the boat rides to see what would happen. SURPRISE best of the day and I had to re-trim steering to STRAIGHT which added 1-2 mph. Eagle Tree and Video tomorrow just too tired tonight. Mike
I had a considerable loss of velocity (with some extra noise) when my Revolt's sutffing tube got loose; which augmented the friction inside it. Have you check the stuffing tube has not moved and/or loosened?
Mike,Originally posted by Mike CarusoThank you for the question. My stuffing box came loose during pre-fight before it ever hit the water. Everything mechanically is good. I wish I knew how to check the motor strength? Before I ran maybe if I took a oz/in reading with a short wrench on the cable nut to measure the magnets load on each pole. I hope someone can help as the boat is going to sit until I know what to buy to fix it. I just don't want to throw $$$$ at it.
P.S. It all started after the day I turned the throttle trim to bring the boat in slowly by some rocks. Never been the correct since....ESC tweaked?
if it did not let the smoke out take a close look at the motor connectors. Typically" if it does not let the smoke out its not the Controller.. Might..might.. be the motor but start with the connectors to the motor.
Also.. Start over with the radio setup.. turn the TH trim to the 2 O clock position and start over.
Grim
