Revolt 30 just received - Stock Transom needs QC!
  • gyrotron
    • 499
    Hello,
    After inspecting my Revolt 30 before 1st maiden run I found there are no lock nuts fastening any of the hardware at the transom. I took the attached testimonial picture. I would like Grimracer to take a look at this one... because there is some QC needed I think.
  • rjs62
    • 17
    wow.... that really sucks !
    • gyrotron
      • 499
      It does and I also found a leak apparently coming from the rudder back plate...
        I can understand how you feel, but I remember reading earlier posts regarding this matter, it is normal, there isn't any lock nut , the metal plates are threaded and act as fasteners. As for leaking, I check all RTR boats with anything that can break loose or leak before maiden just as you have done.
        http://forums.offshoreelectrics.com/...not-have-bolts
        As for the leak, you might have to seal it with either silicone or epoxy. Many people don't like silicone INSIDE their hull, because it leaves oily residue that prevents any good epoxing needs. Before doing that I would check if the rudder is firmly attached to the transom. If you don't want to apply anything inside, I would loosen the rudder bracket and put silicone OUTSIDE where the bracket is attached to the transom, I do that to all my boats now, a little is enough, don't need to have an oozing blob.
        just my $.02
        Have fun and keep us posted!
        • siberianhusky
          • Dec 2009
          • 2206
          AQ has been mounting hardware like that since at least the first generation of SV27, never heard of anybody having problems with it.
          If you have holes in a boat there is a chance they will leak, all boats wether RTR of built by you should be checked in a bathtub for leaks around all of the mounting hardware.
          I personally don't like silicone anywhere near my boats, the stuff is horrible. ONce it's there it's there forever, even if you think it's gone from the surface it's still there. Makes repairs and paint just about impossible due to the properties of silicone.
          Use a good latex caulking like Mono, can be removed down the road if needed, can be painted over and lasts just as long as silicone.
          • gyrotron
            • 499
            just my $.02
            TL,
            On the link you send me people say it is ok because back plates are threaded and then Grimracer says:
            "The replacement hardware sets come with tapped plates and nuts." Humm, just wondering how so... I will also seal the rudder backplate and lets hope that will take care of the leak. Well, I'll go ahead with maiden run w/o the lock nuts like everyone else and just for the sake of it contact AQ and see if they at least send me the replacement hardware.
            Thank You.
            • gyrotron
              • 499
              Hello Sibe,
              I will go ahead and use the Mono sealant you recommend.
              Thank you,
              • Heaving Earth
                • 1929
                They prolly send nuts in case you don't want to use the plates, or wish to use the hardware on another project on which the plates won't fit.
                Or it's just a typo.
                Why would they send you replacement hardware? There's nothing wrong with yours....
                Go to the hardware store and buy nuts if you're that OCD about it
                  I think when you order the hard ware set, the nuts are included. I think it saves quite alot of money for AquaCraft to have the threaded metal plate, this way the worker only has to align the holes once and both screws are in so to speak, no need to worry individual nuts. Since they are not paying YOU to do the job, they figure might as well to include the nuts for the set. lol.
                  I learned something too, you should heed the advice from siberianhusky: check out that stuff he recommended. I will be checking it out.
                  • gyrotron
                    • 499
                    Ok, I won't worry anymore about the back plates and just go ahead a fix the leak. Thx
                    • gyrotron
                      • 499
                      Yeah I'll get the sealing product and fix the leak
                      • dana
                        • Mar 2010
                        • 3660
                        have you tried just cranking the bolts tight to stop the leak? i have NEVER used silicone to stop a leak in a boat yet…. usually just having the bolts tight will stop leaks
                        • gyrotron
                          • 499
                          I'll just go ahead and apply the sealant Sibe recommended. Thanks.
                          • dana
                            • Mar 2010
                            • 3660
                            plumbers putty also works good. plus it never dries out and is removable, and isnt made with silicone, so future glueing or painting is ok
                            • gyrotron
                              • 499
                              Dana,
                              I believe if I use the plummer's putty I won't have to wait until it dries so I am going to go this route first and see how it behaves. I am eager for the maiden run.
                              Good time saver tip!
