I just ordered a Revolt 30. I was wondering if someone could tell me what I need to put in the boat to obtain speeds of about the mid 40s. This is my first boat. I quit racing touring car. Wanted to try something different and just play around and have some fun. So any info will be greatly appreciated. Please include part numbers if possible.
Revolt 30 Speed help...
Thanks. Now this will be my first boat. From what I understand you have to balance and sharpen a new prop? I have never done this and am worried I will mess up the prop. Is there any place that sells props already sharpened. I know off shore elecrics does, but they seem to be out of stock at the moment. Do you of anywhere else?Originally posted by nickB722 View PostThe Revolt section has quite a bit of info on this. From what I recall, an Octura x642 or m445 help boost the top end on the Revolt considerably.
If Your charger is capable of a 12v input then yeah. Remember to make sure your battery is not drained and you are not left stranded. It's a very fun boat. Run it and tweak it a lil bit and you'll be having fun.
I've seen some reviews that are not so great. You should double check the servo tray and motor mount, to make sure that they are attached to the Hull and won't come off during your run. Make sure you keep your shaft greased and tape your hatch to keep water out of the hull.
Balancing and sharpening the prop will increase the performance of the boat.Q: Do you know the difference between Men and Boys...?
A: The price of their toys.
Thank youOriginally posted by Shovelnoserc View PostIf Your charger is capable of a 12v input then yeah. Remember to make sure your battery is not drained and you are not left stranded. It's a very fun boat. Run it and tweak it a lil bit and you'll be having fun.
I recently got my first hobby grade boat as well, so sharpening and balancing props was new to me too (granted I have experience as a machinist and in working on full scale boats). It's not a very difficult process, just takes a file or two, a balancer, protective equipment, time, and patience. I had my m445 balanced, sharpened, and polished within a couple hours. I'm sure it's not perfect, beautiful or up to racing standards, but it's good enough to improve the boat's performance and balance in a static sense. There's a how-to article on the tips section of the OSE main site.Originally posted by kobiwan73 View PostThanks. Now this will be my first boat. From what I understand you have to balance and sharpen a new prop? I have never done this and am worried I will mess up the prop. Is there any place that sells props already sharpened. I know off shore elecrics does, but they seem to be out of stock at the moment. Do you of anywhere else?
