motor
  • daverr
    • May 2013
    • 5
    motor
    I have a 4500kv motor from a mini eight will it make the boat faster
    Hi Welcome!
    The answer to your question will be a few other questions: how big is your boat? How many cells are you planning on using? What size prop?
    I can tell you this: unless it is a small boat with a smallish prop, and I mean no bigger than 15" ( the length of the hull that is) , and running only on 2 cell, it is possible to use such a high kv motor.
    • daverr
      • May 2013
      • 5
      Minimono
      Stock with 3 s 25 c 2100 may I'm going to get a x432 prop this weekend. Thanks for the help
        4500kv is too high, you will be better off getting a motor in the 3200kv range and 3s will be fast!
        4500kv at 11.1volts, unloaded RPM is 49,950, way too high, and you are not running a SAW set up. I too wish AquaCraft will put a slightly higher kv motor in those boats, they are really aiming for the broadest spectrum of potential buyers.
        • daverr
          • May 2013
          • 5
          Thanks
