Sent from my C771 using Tapatalk 2
Brand New Mini Mono ESC Questions. 2013
I have almost the same configuration, but the tream tabs are wider but not larger (from the aquacraft Rio).....not good solition. I am building news one, so to eliminate the torque bounce.
If you get a better solution, share it :)
Also running 430 prop, 432 was too much torque.
Here is a pinture and I will post a video later
By the way, nice MM and trailer.
Sent from my iPad using Tapatalk HD
I would like to see some video of how it is running with the side to side torque.
The prop is a little big for that hull, And you should make some longer trim tabs for it.
Try a 30mm prop and adding about 1/2" longer to the stock size trim tabs and 1/2"wider.
You will need to nip the starboard side one to miss the rudder bracket,
But I think it may help a lot with it.
There are a couple other mods you could do to the hull setup,
To make it handle better, But not sure on how far you want to go in modding things.
Sent from my C771 using Tapatalk 2Attached Files
Yes I just looked at your album,
Looks like a nice truck with the mystic.
Also can you take a picture right now of your mystic inside setup ?
I need to check something on it.
1 1/2 Inch Micro Rudder w/ water pickupOriginally posted by Garrett View PostWhere did you find that rudder? I just broke my plastic one today while shooting video.
Can you explain how you do the self-rising modification in the cowling? Does it work every time?
If you have picture….it would be great.
Thanks.
I just cut a hole in the cowling and when its upside down it fills with water and slowly rolls to the side because the weight in the bottom, and then I add some throttle.
I fabricated some new trim tabs from some old aluminum I had in the shop. What do you think?
What are the dimensions?Originally posted by Garrett View PostI fabricated some new trim tabs from some old aluminum I had in the shop. What do you think?
They will definitely do the job….seems to me a little longer ¿?
I will build mines on the weekend, but I will not cut the turn fins.
Thanks for the sharing pictures.
They're 1 1/2 inches wide at the rear, and one inch at the front.
The tab from the hull to the end is 1 1/2". And overall is 1 3/4" inches.
the material I used is thinner than the stock tabs, so I might need to install mine on top of the new ones for support.
