flex cable
  • MAMBA2200
    I need a scooby snack
    • 1347
    flex cable
    just bought one of these for my son for christmas and wanted to get a upgraded flex shaft does anyone know who sells one that is ready to go for this boat im gonna run a 35a seaking on stock motor for now but i need the cable
  • SirBudman32
    • Aug 2011
    • 701
    Just unsolder the flex and get a piece of .047 Piano wire and put back in. did it to my daughters Mini.
    Modified Jae21, Stock Jae21, Cheetah, Ul-1, Shock Wave 26 V2 (Rescue Boat).
    • MAMBA2200
      • 1347
      do you need a torch to solder it or can u use a solder gun
      • SirBudman32
        • Aug 2011
        • 701
        I used a torch but should be able to do with solder iron
        • MAMBA2200
          • 1347
          can u use one of those butane torches
          • SirBudman32
            • Aug 2011
            • 701
            Thats what I used.
            • MAMBA2200
              • 1347
              and also can u use the same technique for soldering the flex cables?
              • MAMBA2200
                • 1347
                any special solder to use?
                • SirBudman32
                  • Aug 2011
                  • 701
                  I just heated up the shaft till the flex came out and then heated up the wire and shaft and but them back together.
                  • Jeff Wohlt
                    • 2740
                    I am working on a new 062 wire drive with new x432 prop and drive dog. I could mske new couplers but drilling out 47 to 62 is simple. Anyone interest? Getting a lot of emsils on this.
                    www.rcraceboat.com
                    jwohlt5362@yahoo.com
                    • Sobie2
                      • 15
                      Ok Jeff,
                      I just went to your site and ordered up your driveshaft setup. I had all the stuff from coupler to prop not for the octura 098 flexshaft but have been to busy to gut the boat (and I didn't want to). I already have my 3900 kv watercooled inrunner/outrunner (I don't remember its blue and from hobbyking) and a SeaKing 35a in place. All I had to do was enlarge the cowl opening to shoehorn in the motor, and then trim the motor mount to make the water cooling tube not kink. Up next is solder on a deans connector. Then install Jeff's 062 shaft. I have 3 octura props waiting Y531, X432, and X632. All in all its pretty plug and play should be good.
                      After this its some kind of 6s rig, Revolt 30 or Impulse 31 (or any other suggestion).
                      Sobie2
                      • Sobie2
                        • 15
                        I got my Jeff Wohlt 062 setup last week in the mail. I plan on installing it soon. I will let people know how it goes when finished.
                        Sobie2
                        • AustinWolv
                          • Sep 2013
                          • 175
                          Sobie, did you run it?
                          • Sobie2
                            • 15
                            No I haven't run it, the kit was not a quick plugin play as advertised. You had to drill out the driveshaft with a 1/8" drill bit and when I tried that the driveshaft spun out and the bit got stuck and 1/8 isn't big enough. So it's on hold till later. I even have a complete octura 098 shaft kit but heard this was an easy one... Nope
                            Sobie2
                            • jrmagooo
                              • May 2007
                              • 18
                              hi sobie 2. thinking of getting wohlt minimono kit also. saw your post and wondering if you made any progress. thanks jim
