MiniMono metal prop upgrade?
  • vans552
    • Aug 2011
    • 10
    Does anyone know a good metal prop for the Aquacraft minimono? I saw that octura has a couple that are the right size but im not for sure , but any suggestions?
    stock prop is 30mm two blade frp prop with a 1/8(3.2mm) prop shaft
  • Alfa Spirit
    • 2131
    Tenshock CNC props
    • vfrman40
      • Feb 2010
      • 9
      prop
      which octura prop would be recommended
      • chirotray
        DocFowler
        • 139
        I've got the y531 on mine. (purple plastic) After I get my issues worked out I may try a x432 just to see how it reacts.
        Yes its fast, yes it will go far away, yes its expensive. No you cant try it.
        • pculton4
          • Jun 2011
          • 7
          Minimono prop upgrade
          I just put an Octura x432 on mine with a bullet nut. It makes a huge difference in the acceleration. Im not sure about the top speed but Im guessing its faster. I cant even get close to opening this thing in my pool and havent been to the pond yet.
          • flyingjunky
            • 32
            Just ordered the x432 also for this and i just switched out that junky esc. for a 35 amp watercooling. I have the esc. already installed and i can notice a huge difference.
            • pculton4
              • Jun 2011
              • 7
              What brand of ESC did you go with? I would be interested in changing mine out also. Thanks.
              • iratner
                • 31
                I am using an Octura 430 prop and the shorter Mini-Rio rudder. I also removed the turn fins as they are unneccessary.
                Overall, once you replace the ESC and the drive shaft, it's a great boat!
                • flyingjunky
                  • 32
                  What did you replace the drive shaft with??
                  • flyingjunky
                    • 32
                    http://www.hobbypartz.com/seaking35aboat.html have it in my small bolt and no issues so far
                      • 9479
                      Anyone run a prop bigger than 32mm?
                      • pculton4
                        • Jun 2011
                        • 7
                        Was that ESC easy to install? I have big hands and Im not very handy with these little boats?? I would also like to know what drive shaft was used by the other person who posted on here. Its not a good sign when they include an extra shaft with the boat!! Thanks guys!!
                        • pculton4
                          • Jun 2011
                          • 7
                          I dont see the wire that runs from the esc to the receiver in the picture of the 30 amp ESC from china. Thats what scared me. I need a direct replacement. If Im going to have to modify any parts I will be screwed!!
                          • iratner
                            • 31
                            Change the drive shaft to an Octura .098 shaft. You will need to find a drive dog that will fit both the boat and the shaft as the one that comes with .098 will not fit the boat.
                            • pculton4
                              • Jun 2011
                              • 7
                              Thank you for the info. Im actuallly sending the boat back to Hobby Services tomorrow. I put the battery in yesterday and the ESC caught fire. I had to run outside and rip it out. Hopefully they will send me a new one asap.
