Mini Rio rescue boat
  • Radness69
    • Feb 2014
    • 2
    Hey folks just wondering what your thoughts are regarding a rescue/retrieval boat for my Blackjack 29. Does this little hotrod have enough power to haul my BJ29 in with a line and tennis ball hook combo? It would be a bone stock Mini Rio with a 2000 mah Lipo 2S.(LVD alarm)
    Also considered the Rio with float and arms style setup for collecting BJ29.
    Thanks!
    Chris
    IMO the Mini Rio is not a good candidate for the task mentioned above. It is too small and the little motor with the ESC/radio combo unit makes it hard to avoid issues with heat build-up and signal loss at a range that might exceed the system's capability.
    At $20 more, you will be better served with the RIO EP, the dual rudder turns the boat on a dime even at slow speed. The only thing you need to be aware of is that the ESC is non-water cooled, if you push too hard, it will fry. Also this boat is a ton of fun, so in no time you will want to make her run faster, as I did with a BL conversion, so now I am rescue-boat-less.
      There is a video of it doing it thing some where on hear.
      • phil t
        • Feb 2010
        • 195
        Allyou have to do is run a line out to the dead boat and circle it once, then reel in the line, dead boat, and retrieve boat. The retrive boat doesnt have to push or pull. I just use a small zig zag forthat job
        Phil Thomas
        email supersport45@aol.com
        http://www.philthomashydros.com
        • Radness69
          • Feb 2014
          • 2
          Great input guys thanks very much!!
          • jerry123
            • Feb 2014
            • 75
            https://www.youtube.com/watch?v=iCSzhyfHF3w
            I use a Walmart boat for my small electric boats.
            • rearwheelin
              • 2101
              Inline rudder turns best for singly prop retrieving
              --Albert Einstein
