water jacket Help please!
  • Oddball185
    • Jul 2009
    • 33
    A word of advice to anyone removing the water jacket: DON'T - Unless you absolutely have to. It is VERY difficult to re-install.
    Ok, I have been fighting with this thing for hours! I have searched for a step by step but have not found one....... I could have missed it?
    I have orderd the upgrade from OFE but it wont be here untill next week.
    Thanks!
  • egneg
    • 4759
    Did you see this thread?
    http://forums.offshoreelectrics.com/...ead.php?t=6147
    and if all else fails seal the ends with silicone at both areas where the can meets the motor and at the end bells - it might not be pretty but it works.
    IMPBA 20481S D-12
    • Oddball185
      • Jul 2009
      • 33
      Yep....I missed that one! Thanks!
      I wil give it a try.
      • detox
        • 2357
        The UL-1/Grimracer water jacket is a piece of SH*T.
        • longballlumber
          • 3417
          Once I received the correct parts, my UL-1 water jacket has worked fine.
          Mike
          • Capt. Crash
            • Jan 2009
            • 341
            Mine worked after 15 rounds of a knock down drag out fight....and after I untwisted the o-ring and re-lubed with Vaseline. Not a drop leaked since.
            • longballlumber
              • 3417
              I agree the install is a little tricky, but the key is having the correct parts and patience!!!
              • Oddball185
                • Jul 2009
                • 33
                Well after fighting with it a few more hours, it kicked me in the junk because I tore the o-ring in half! I went to my local hard ware store, but the only O-ring they had was a little smaller. I stretched it over the motor and used teflon tape on the threds. It worked! no leaks and it was much easer to get on because of the smaller o-ring. Now for me this is only a temp fix because I have the OSE water jacket on oder. At least now i dont have to wait to giver her another run! Now i just need to figuer out way the RX has such short range? I'm guessing it might be bad because i got it wet. It's working but not more than about 50 feet or so than it goes out of range!???
                • Grimracer
                  • 660
                  the new updated parts are the key..
                  The new o rings have a 2mm cord.. (.080") the old ones had/have 2.5mm.
                  If you do not have the new rings call hobby services to see if they have more.. if they are the old you will also get a new set of end caps.
                  Grim
                  • TCR
                    • 139
                    Chitcan the UL-1 waterjacket, it is the crapiest design other than the blue one they make for the SV. Move the RX as far away from the other electronics as you can. I put mine behind the steering servo and it works great. Also and obviously check and make sure your TX batts are fresh.
                    Tom
                    • Oddball185
                      • Jul 2009
                      • 33
                      Thanks!
                      I tried moving the RX back and still cuts out like within 2O feet! I bench tested it and walked away untill it quit. Think its toast? I looked online and seams like most are out of stock on this RX untill Mid Aug!
                      • egneg
                        • 4759
                        Thanks!
                        That is a shame ... I have 3 of them now so I must have been lucky when I needed them.
                        IMPBA 20481S D-12
                        • Grimracer
                          • 660
                          are you sure its not the cap? Does the boat just stop?
                          BTY.. I REALY like the stock water jacket!
                          Grim
                          • Oddball185
                            • Jul 2009
                            • 33
                            No I am not really sure. The cap looks ok not swollen the end is perfectly flat.
                            Thanks!
                            • Grimracer
                              • 660
                              if you want.. lets change it...
                              send a mail to grimracercnc@yahoo.com
                              Lets see what we can do about getting you up and running.
                              Grim
