UL-1 prop question
  • lincpimp
    • Jul 2007
    • 252
    UL-1 prop question
    Hey Guys, need some help from the pros!
    I just acquired a UL-1, it has a 6xl in it, and I plan to run 4s lipo. Not looking for a speed demon, 50mph max.
    Looking at props, the octura x438 looks to be about right, but I wounder if the Grimracer L38x55 would be a better choice. They appear to be very similar in spec.
    I see that the grimracer is listed as a lifting prop, and I thought that was what you had to use on a hydro (this is my first hydro) but I also see that the UL-1 runs the same prop that the supervee does stock, so I am a bit confused...
    Please steer me in the right direction, I just put around the local pond, so good temps and runtime beat speed for me!
    Thanks!
    "These rocky mountains aren't very rocky!" "Yeah, that John Denver is full of S**t!"
  • hurricane
    • 15
    Ok with the 6xl and 4cell lipo I would run X632 or X432.
    I run both of these in some of my boats just make sure you have good cooling for everything.
    I get right around 60mph some times a bit more if the water is smooth and no wind.
    test these props out let me know how it works for you.
    Mine hooks and fly's love it.
    • detox
      • 2357
      WOW...6xl 2779kv motor using 4s lipo has unloaded prop speed of around 39000 rpm +. You better use a small prop or you will burn up ESC.
