Water in the hull ?
  • Capt. Crash
    • Jan 2009
    • 301
    My original motor is still running fine...but I didn't tax it with any thing bigger than a 40X57/3 prop and never run it hot. I keep every thing lubed. I use the recommended pair of 2 cell lipos in series. The only blown motors I've heard of were over volted. I'm not sure why ESCs are blowing caps...mine is still working great.
    The only major issues I had were structural.
      • 9479
      Originally posted by TCR View Post
      Bull! I have had to replace 2 of these ESCs that I don't run over 5 mins,both have had blown caps, and 1 motor w/ less than 2 hrs use. THese boats are not built enough for racers and especially are not built for the weekend basher. Aquacraft cheerleaders say what you want; I have 3 UL-1s do you?
      Wow! chill out...
      I have well over 30 runs on my UL-1 and not one issue with it..
      Hmm my guess is I have it set up right and not over powering anything
      • TCR
        • 139
        Wow! chill out...
        My guess is I have more experience w/ multiple UL-1s than you, but that's an assumption and I could be wrong. Also I haven't overpropped any of them and my set ups are more loose than wet. So if good cells, short run times and not overpropping isn't the answer what is?
        Tom
        • TCR
          • 139
          My batts are all 7.4V 2s Maxamps 5250s or polyquest 6000s, the most prop I've used is the 40x57; I really enjoy the 40x52/3. Temps stay below 135 or so. The one motor I had go bad had to be bad from the start to die so soon.
          Tom
            • 9479
            yep, just your assumption
            • TCR
              • 139
              Then let's here it, you have how many UL-1s and have had no issues due to your superior knowledge? Facts please. These threads are to inform people who may or may not own a UL-1, not bust the balls of other members. So enlighten us and better yet tell me where I'm going wrong w/ the 3 UL-1s that I own, w/ the mediocre electronics we have to tip-toe around. I will THEN stand down on questioning this RTR and it's quality.... Problem is I have 3 and have had one issue or another w/ ALL OF THEM. A freakin' Blackjack 26's quality is superior, design is not but the quality IS. The floor is yours...
              Tom
                • 9479
                What I think of when someone starts of a with a bragg
                • TCR
                  • 139
                  Please read what you wrote; then translate in english for the rest of us please
                  "someone starts of a with a bragg"
                  Your laughing, but your not getting the PMs that I am about you...
                  Tom
                    • 9479
                    Lets get back to this thread about water in the hull...
                    I do pull the plug and let my UL-1 drain out some water after each day of running..
                    • Christaphason
                      • Jun 2009
                      • 104
                      I have heard of the water cooling jackets leaking and filling the hull... Aquacraft will send you an upgraded cooling jacket for free if you call them.
                      • FoxProGT
                        • Jun 2009
                        • 37
                        you must mean it lets water in the electronic bay. maybe i will call for that replacement jacket anyway tho :D
                          • 9479
                          Mine had a slight leak, and all that was needed was to tighten up the ends..
                          work great now..
                          • Christaphason
                            • Jun 2009
                            • 104
                            Also tell Aquacraft your reciever was ruined due to the jacket leaking!
                              • 9479
                              Don't forget about the esc!
                              • FoxProGT
                                • Jun 2009
                                • 37
                                :O mwwahahahahaa
