More Prop Testing
  • detox
    • 2357
    I've said it before, but adding weight to lefthand side of hull will help UL-1 handle better (less chine walk). The steep 4 degree AOA helps hull be loose and fast down the straits. The excellent turn fin keeps boat planted in turns if adjusted correctly.
    • ronn25
      • Jun 2009
      • 51
      I will try this...seems I have to put a lot of negative angle on the strut to keep it from blowing over, but it slows the speed down. I had to add about 6 oz to my miss vegas because it would blow over above 45mph
      Miss Vegas 47mph OS .18cvr
      TC 31 OS .21vz-m
      UL-1
      • Capt. Crash
        • Jan 2009
        • 341
        By left do you mean port side?
        • detox
          • 2357
          Correct...lefthand side of boat as if sitting in boat and facing forward. Opposite side to turnfin side.
          • Capt. Crash
            • Jan 2009
            • 341
            Hmmmm....I have more weight in the starboard side due to all the added glass of the turn fin/sponson repairs....I wonder if that makes my boat more prone to wobble?
            I would think more weight in the turn fin sponson would help it plant better in the corners...but what do I know...it's my first hydro
            What's the reason more weight in the port side sponson is better...counter acting prop torque?
            • detox
              • 2357
              Correct.
              The starboard side is held down with turn fin if adjusted properly...read manual.
              • Drag Boat Bob
                • Apr 2009
                • 304
                It used to be that we ran left hand props because the driver sat on the left/port side (sorry, drag racing days again). This weight helped compensate for the counter-rotation "lift" of the prop torque and helped balance things out.
                With added weight on the right/starboard side, it would be like adding to the counter-rotation lift, and could very well ADD to the torque roll and subsequent bounce.
                I agree with Detox. Adding weight to the left/port side is the most logical when running left hand props. Also the bigger the prop, the more counter-rotation torque.
                Currently, in the big boat world, this was cured by running twin counter-rotating props in TFH.
                In my prop testing, I am finding that as I increase the prop size, the lift on the left/port side is greater. Only in absolute glass water is this not too much of a problem. With a slight chop things start to get hopping...
                Then of course, I am still new at these rc boats...
                • Drag Boat Bob
                  • Apr 2009
                  • 304
                  Well, I have finished prop testing for now and here is what happened:
                  L40x57/3 - (GPS= 50.9 mph) I spent 2 hours re-sharpening and I think I got carried away since it looked a bit smaller when I was finished. It was so sharp you could shave with it. No more cavitation problems to speak of as long as you keep the speed up. This is a good prop.
                  m445 - (GPS= 51.1 mph) This is a wild ride. I could not keep it under control in the corners. It was out of control with ANY cross wind. Exciting, but probably too much for my setup. I do not understand why this prop was much wilder (and a bit slower) than the L42x66.
                  Bottom line with the props tested: I prefer the L38x63 as the best all around prop. Good speed and great acceleration.
                  Interesting finding: The more I tested the larger props the slower the boat went. The motor leads were up to 151 degrees (I may have a problem here). I think I will have to change to the bullet plugs.
                  I also have been testing flex cable lubricants (even mayonnaise) and have a lot more to do on this subject, but I can say that there is 3 to 4 mph difference here (another post).
                    • 9481
                    Start the thread!
                    • longballlumber
                      • 3417
                      Bob,
                      Can you give us the rest of your set up:
                      Strut depth and angle
                      battery set up (mah, how many P)
                      Turn fin +/- angle
                      Thanks
                      Mike
                      • Drag Boat Bob
                        • Apr 2009
                        • 304
                        Originally posted by longballlumber View Post
                        Bob,
                        Turn fin +/- angle
                        Thanks
                        Mike
                        I think I have given this sometime back, but here goes.
                        Strut: 1" (dropped from the stock 7/8")
                        Strut Angle: Approx 1-2 degree negative angle. This is the way it came.
                        Batteries: (2) Max Amps 6500 mAH, 2S in series.
                        Turn fin: stock lower setting. I tried it raised to the next hole, but couldn't corner well.
                        Rudder: Removed lower bolt and used a Kintec nylon (thinner) shear bolt. This allowed for a few degrees of positive angle.
                        • longballlumber
                          • 3417
                          Thanks for your reply!!!!
                          • Drag Boat Bob
                            • Apr 2009
                            • 304
                            Start the thread!
                            I won't be able to continue the testing for 3-4 weeks, but this should give me time to change the motor connectors to larger ones. Their increased temperature was not indicative of the other components.
                            • detox
                              • 2357
                              Octura x442 works verywell !
                              • Drag Boat Bob
                                • Apr 2009
                                • 304
                                Aren't you running that NUclear power plant though?
                                Don't forget I'm running the stock spinner.
