UL-1 Upgrade Help
  • nate
    • 1652
    Cool. Im about to start another thread for my next build. Check out boat building in about 15minutes.
    LMT
    LehnerMotorenTechnik.com
    • papa
      • Jun 2009
      • 11
      thanks Guys
      I will give it a go and let you all know how we go, I will be going for the 1515-1Ys with water cooling and running the ETTI 150 with caps board. I will try both the m440 and 445
      thanks for the help
      • nate
        • 1652
        Originally posted by papa View Post
        thanks Guys
        thanks for the help
        I think Iv changed my mind as Detox could be right, don't run the x445, maybe run an x442 first.
        LMT
        • papa
          • Jun 2009
          • 11
          Hi All
          I have decided that this UL-1 needs my help in order to get it to race trim and perform well and last a couple of seasons.
          I have started off by removing stuffing tube and will replace with a thicker and tube that suits .187 flex cable.
          I have also cut two holes on each of the sponsons to see what is actually done by the factory and I was not impressed, ( fine for everyday play boat) so I will now add the sponson plates that Darin from this forum has kindly uploaded but I will do it on each side to stiffen the rear of both sponsons because I feel these boats stock are weak in these areas and need attention, I also want to add a piece of ply and resin over the ride pads (sponsons) to try and also stiffen the sponson adding some weight may help with blow overs,,,,,, my question is how much weight should I add ? If any. I’m going to also install Nut inserts behind the engine mounts because from the photos below you will see its only a small piece of ply and in my case the left hand side of the mounts are screwed just on the edge of this small piece of ply.
          I also noticed that both sponsons have a piece of lead tucked all the way up the front of the sponsons (pictured below)
          I would not recommend this type of work to the everyday hobbyist as it requires a lot of work to repair to the glass and in my case my glass work is ok and I think if you are going to race it and we all know when we race and crash we want minimum or no damage done
          • papa
            • Jun 2009
            • 11
            some more pictures of upgrades and repaired cracks.
            • papa
              • Jun 2009
              • 11
              Nearly Done,,, just need to fit it all back and make a new cowling to suit.
                • 9479
                Nice!
                I've thought about doing my Mean Machine this color..
                • detox
                  • 2310
                  Cool dissection of the UL-1, but I think all those extra mods are not needed. The latest updated UL-1 hull from Auquacraft allready has the beefed up turn fin area and lead weights mounted in tips of sponsons.
                  Try adding weight to lefthand side of hull to counter prop rotation.
                  Beautiful body work and paint BTW.
                  • papa
                    • Jun 2009
                    • 11
                    This is the latest UL-1 and Im sorry to say the sponsons/Turn fin Area are NOT beefed up at the slightest. Yes they do come with Lead weights tucked all the way up the front but the rest of it is really not what I call race crash ready.
                    • Rumdog
                      • 6453
                      What a friggin joke! Still a fun boat with some mods though!
                      • TCR
                        • 139
                        Thanks for all the great info George, I'm glad someone shed light on this hull. For a couple bucks more in parts and labor this really could have been a sound boat. It might have cost us an additional 50.00 or so, but it'd be worth it. I'll run mine til they bust up and just buy another, as said above it's a very FUN RTR.
                        Tom
                        • Grimracer
                          • 656
                          I want to clarify... ALL boats shipping FROM US after 6-15 are updated..you must (for some reasion) gotten ahold of an older unit..
                          O yea.. the weights have been in there from day one.. nothing new there..
                          ROCK ON DUDES!
                          Grim
                            • 9479
                            ROCK ON DUDES!
                            Grim
                            Thanks Grim!
                            • TCR
                              • 139
                              ROCK ON DUDES!
                              Grim
                              This is not what Lisa is telling people.
                              Tom
                                • 9479
                                these riggs are alot of fun for a RTR !
