motor transplant
  • properchopper
    rcgoatbuild@snotmail.com
    • 7708
    motor transplant
    I needed to "borrow" the UL-1 motor for my VS-1, so I stuck a spare SV-27 motor in the UL-1. Best combo I've run so far ! Not the fastest, but superb heat race setup ; great acceleration and good top speed [ estimate at @ mid to upper forties, nearly no chine wobble at all, gets up & out easily].
    Setup : SV-27 motor
    CC 80 watercooled w. Etti caps
    M445 ; lower KV & lots of torque of SV 27 motor pulls this prop well
    Elite 2S 35C 5000's splayed into sponsons [ picture taken before swap]
    7 oz. lead ballast in front of tub
    1 1/8 strut depth
    Fuller's turn fin - full throttle turns with no hint of wobble
    G-10 ride pads - pretty sure these contribute to the great cornering
    Temps all reasonable, with more than enough runtime. Not an "all-out bonzai" top speed setup, but I'm sticking with this for antic-free fun running and heat racing.
  • alvinsmith75
    • 635
    That looks great! I love the battery idea. Should be fine I get no water at all in my tub or hull ever.
    • Drag Boat Bob
      • Apr 2009
      • 304
      Setup : SV-27 motor
      1 1/8 strut depth
      Great Info!
      Love the battery setup, but surprised that you would need that much additional weight (7 oz.) up front with the CG moved forward also.
      Did you have any issues using the M445 with the UL-1 motor?
      • properchopper
        • 7708
        Originally posted by Drag Boat Bob View Post
        Great Info!
        Kept the nose down with the UL-1 motor & higher speeds
        M445 violently fast ! Hold on to your hat !
        • detox
          • 2357
          I tried that same combo except I used the SV27 esc. Using m445 and other props motor temps got really hot...175 and up, but boat never died on water.
            • 9481
            will the SV motor use less amps giving a little longer run times?
            I have a spare SV motor, that I might give a try
            • properchopper
              • 7708
              Depends a lot on which prop you use. Go conservative.
