With my strut and sponsons resting on LEVEL setup board the AOA (Angle Of Attack) of my UL- 1 sponsons measure 4 degrees. That is with strut lowered 1 3/16" below transon / hull floor. To adjust my sponson angle to a more WET 3 degree angle I will have to lower strut aditional 5/16" to setup board. I will try this lower strut setting (1 1/2") to see if it helps make my UL-1 more stable in race water. I will have to bend the brass stuffing tube to do this.
UL-1's Sponson AOA (4 degrees)
I'd be interested to hear of your results. I've thought of adding another layer of
G-10 ridepad[s] at a shallower angle to get less AOA, also cutting out the inside of the forward tub area to get the batteries partially inside the sponsons to change the moment of torque, reducing the death dance. It'll get the CG forward some as well.
Keep us posted.
I see your point, although I'm not sure raising the CG such a small amount would upset anything. Before I open up the tub, I plan to put my ballast taped to the top of the sponsons to see if the wider distribution of weight has a calming effect on the wobble. Once inside It'll have a lower roll center, however. We'll see.2008 NAMBA P-Mono & P-Offshore Nat'l 2-Lap Record Holder; '15 P-Cat, P-Ltd Cat 2-Lap
Here's more pictures to help decide how to close in AOA. Perhaps gluing a 1/4" door shim under each sponson would do the trick. Angle needs to be closed half way to be 2 degrees. Making a door shim should not be hard to do using bass wood and table saw.Last edited by detox; 06-06-2009, 05:41 AM.
You can get beveled fiberglass door shim material at Home Depot and Lowes. I have used it to make ride pads and also to change the AOA.
Someone please explain to me how that is going to affect the ride and help the hospital hop. The only part of the pad on the water is the very back, when on plane.
I'm thinking rounding off the rear outside edges of the sponsons might be worth a try. This might help with the boat being upset when crossing wakes.
Reducing sponson angle from four degrees to two degrees will help boat run wetter and be less bouncy, but causing more strain on motor/esc. I am not sure if the stock UL-1 "esc" can handle this extra strain, but my NUE 1515 1Y and Hydra 240 should be able to. I plan on trying different angle ride pads (removable). They will be temporarily attached using 3M contact spray adhessive.
Here's current setup using NUE 1515 1Y 2200kv, Hydra 120 (using the Castle BEC with no failure yet), and Grimracer L38 x 55 prop. UL-1 is a missle using this power combo, but very flighty when crossing wakes. Hopefully reducing sponson angle will help... Air Dam or Spoiler may also be needed.Last edited by detox; 06-05-2009, 02:04 AM.
I purchased the composit door shims, but their width is only 1 1/2"...the UL-1 ride pads are 1 7/8" wide. I will try using bass wood first. I will cut two pieces @ 2 degree angle then hand sand to desired shape. Afterwards I will seal using epoxy finishing resin then paint.Originally posted by Hydromaniac View PostYou can get beveled fiberglass door shim material at Home Depot and Lowes. I have used it to make ride pads and also to change the AOA.
I made some fiberglass G10 plate by compressing epoxy and fiberglass cloth between MDF board (Saran wrap between boards and epoxy prevented epoxy from sticking to MDF. Saran wrap peeled easily from dried epoxy). Homemeade G10 is LOTS cheaper than original G10. It takes four layers of compressed heavy weave fiberglass (Walmart) and epoxy (finishing epoxy) to equal 1/16" thickess. I will try making the bass wood ridepads before trying the fiberglass.Last edited by detox; 06-05-2009, 02:07 AM.
Anxious to hear your ridepad-mod results. I'm testing my theory that the wobble can be reduced by spreading the battery weight further outward to move the roll center outward & at the same time getting the CG a little forward, which I believe will keep the nose better planted. I hope youu don't mind me intruding on this AOA thread, but we're both striving to get similar results.
Attached Files2008 NAMBA P-Mono & P-Offshore Nat'l 2-Lap Record Holder; '15 P-Cat, P-Ltd Cat 2-Lap
Nice idea let us know how it goes. I might try this also as i already have the holes their from reinforcing the sponsons and the turn fin. all i would have to do is cut the bottom i little more to make it flush with the inside tub.Originally posted by properchopper View PostAnxious to hear your ridepad-mod results. I'm testing my theory that the wobble can be reduced by spreading the battery weight further outward to move the roll center outward & at the same time getting the CG a little forward, which I believe will keep the nose better planted. I hope youu don't mind me intruding on this AOA thread, but we're both striving to get similar results.
I'll know Sat or Sun, depending on the weather & report back.Originally posted by line6 View PostNice idea let us know how it goes. I might try this also as i already have the holes their from reinforcing the sponsons and the turn fin. all i would have to do is cut the bottom i little more to make it flush with the inside tub.
I hope your idea works. I once tried adding lead tape weights to the outside lower edge of each sponson (3oz. each side) . It did help some, but not enough.
http://www3.towerhobbies.com/cgi-bin...&I=LXK204&P=ML
A member of our club has done this mod, and it works well, the boat doesnt sponson walk as bad and seems to be more stable in the turns. The only drawback is getting the boat on plane from a dead start, the added weight makes it nearly impossible with certain props.R/C Unlimiteds
NAMBA 237
