UL-1 Power system upgrade arrived!
  • detox
    • 2357
    The Octura collet (long version) should fit without cutting shaft.
    • Jeff Wohlt
      • 2740
      The dremmel works well on shafts.
      www.rcraceboat.com
      jwohlt5362@yahoo.com
      • Capt. Crash
        • Jan 2009
        • 341
        Yes....I've cut off numerous shafts with mine but get a metal cut off disk...the thin brittle ones that come with the tool will shatter and stick in skin...eyes...etc....don't ask!
        Very cool man...I can't wait to hear/see the results!
        • LuckyDuc
          Team Ducati Racing
          • Dec 2008
          • 1058
          My first run results with the Medusa 36-60-2200 and Grim L40x57 prop are below.
          Strut depth was set at 1 1/8". She was chine walking something fierce... I think I need a smaller prop for this motor. She was still fast as she danced across the lake
          The L38x55 and x440/3 should arrive tomorrow. I going to try tweaking my setup to see if I can eliminate the chine walk with this prop while I wait for the other props to arrive.
          • Jeff Wohlt
            • 2740
            Wow...54 mph! I think that is the fastest I have heard of...not including Brian's run.
            How was the heat and all that?
            www.rcraceboat.com
            • Capt. Crash
              • Jan 2009
              • 341
              54mph....cool man!
              Where was that 200+ temp at?
              The chine walk may be that fin. More weight up front may help with it.
              It's looking like a rain out here for the whole weekend....and I'm just about to bust to try out my new setup....RATS!
              • LuckyDuc
                Team Ducati Racing
                • Dec 2008
                • 1058
                Sorry, forgot to label the temp locations...
                High Temp A = Motor can
                High Temp B = ESC to Battery bullet connector
                High Temp C = Motor lead bullet connector (205.7 degrees)
                I plan to fiddle with the strut and turn fin on the next runs to see if I can reduce the walking. It's going to be awhile before I have the new test props balanced and sharpened anyway, so I might as well see if I can get the L40x57 tweaked better.
                • Jeff Wohlt
                  • 2740
                  Love the stats but how do you feel about the motor in general?
                  www.rcraceboat.com
                  • jingalls007
                    • 1172
                    Awesome! 54 mph is fast on the water. Now with the extra KV and the 38X55 I would raise the strut a bit more. The lifter prop's liked the strut at 1" for me, handled better ran cooler at 1" then at 1 1/8". How did she handle in the corners?
                    • LuckyDuc
                      Team Ducati Racing
                      • Dec 2008
                      • 1058
                      I like it. This is not my first Medusa motor though. I have them in two of my EDF jets.
                      • LuckyDuc
                        Team Ducati Racing
                        • Dec 2008
                        • 1058
                        It was chine walking everywhere with the L40x57. I think that prop is too much for that level of rpms and the hull.
                        • jingalls007
                          • 1172
                          I think your right, AND maybe even a X637 or X642 int he future? Isn't this sport/hobby fun, constant things to try out and tinker. so many props, so little money.
                          • Darin Jordan
                            • 9446
                            ... so many props, so little money.
                            SOOO many tweaks you could do to your EXISTING prop to find out that it WAS the right one after all!
                            Darin E. Jordan - Renton, WA
                            • jingalls007
                              • 1172
                              Like??
                              the mo' knowledge the mo' betta'
                              • LuckyDuc
                                Team Ducati Racing
                                • Dec 2008
                                • 1058
                                Octura x440 test
                                I got around to testing my Octura x440 3 blade prop with the Medusa.
                                The best strut depth setting for this prop seemed to be 15/16" below the hull.
                                In short, it had a much higher average lap speed than the L40x57 prop (43mph avg), but had a 2mph slower top end. Temps, Amps, and Watts were much higher though. As you can see by the increased avg lap speed, it was much more stable on the water than the L40x57.
                                I may de-tongue the x440 to see if I can squeeze a little more speed out of it.
                                BTW. The Grim L38x55 was the worst of the 3 props I've tested so far with the Medusa. It was VERY unstable. I tried many different setups, but it didn't help with this prop.
                                x440 stats/chart below.
                                Temp A = Motor Temp
                                Temp B = ESC/Battery Bullet connector temp
                                TEmp C = Motor lead bullet connector temp.
