Drive Dog?
  • Mikey D
    • Apr 2009
    • 3
    Drive Dog?
    Greetings
    My apologies if this was stated elsewhere in the forums. I am a newbie crossing over from the R/C Airplane world.
    I noticed talk of a Octura M440 prop.
    Upon closer inspection of the M440 Prop it appears to have a couple notches (I assume to prevent any slippage on the main shaft. I did not see the matching male notch on the UL-1 stock shaft for the stock propeller.
    I noticed there is an adapter called a "Drive Dog".....am I assuming correct that this would be required to run the Ocutra M440 prop?
    If so there were several to pick from...which one on the "Offshore" site should I pick?
    Thanks
    Mike D.
    My UL-1 is awesome...!
  • sewerpit
    • 139
    if you take the prop on there off , you should see where it fits unless it fell off?
    • egneg
      • 4759
      Sewerpit is right as it does come with a drive dog ... maybe because the stock prop and the drive dog are both black you didn't see it.
      IMPBA 20481S D-12
      • Mikey D
        • Apr 2009
        • 3
        Actually, I was thinking that this did not come with the stock boat, and that I had to order one to use with the M440 prop? Am I wrong?
        • Mikey D
          • Apr 2009
          • 3
          Ahh...you are absolutely right...it was black and I didn't see it Thanks!
