My rebuilt UL1
  • Rumdog
    • 6453
    i'd leave the gps in the front. it's in the nature of a hydro to have to punch it to get it on plane. if the cg is too far back it'll start chine walking pretty badly. looks good in the vids man!! try out the octura 440/3, i was getting about 47mph with that one and hanging real tight corners wot.
    • alvinsmith75
      • 635
      I have an 437/3 and an 537/3. Would these be safe to try?
      • LuckyDuc
        Team Ducati Racing
        • Dec 2008
        • 989
        Nice Vid! Nice battery choice too. Those should pack alot of wallup
        Try and get a temp reading on the solder joint where the parallel meets the ESC leads. Just curious what you're getting after a good 3 minute WOT run.
        • detox
          • 2310
          Alvin, Try using just one of your 4s packs mounted on the left hand side of UL-1. Lighter weight may make you faster. Adjust your turn fin slightly upwards so boat will not be loose in the turns. I run 50mph without use of airdam.
          Here's my setup:
          http://forums.offshoreelectrics.com/...ead.php?t=7539
          • alvinsmith75
            • 635
            2nd run specs
            Prop octura y537/3
            run time 3min 40sec
            total distance traveled 1.71 mi.
            MPH on gps 46.4
            Temps
            Motor 125
            esc and caps 109
            lipos 96
            traxxas connectors 86
            Temp @ parallel connection 94
            When I put my batteries on charge they were @ 15.5v and when thay finished they had taken 1534mah
            What does this number mean anyway? (taken 1534mah)
            Thanks,
            Alvin
            • jingalls007
              • 1015
              Alvin,
              How does it handle coming out of the corners with that setup?
              • alvinsmith75
                • 635
                Originally posted by jingalls007 View Post
                Alvin,
                Not sure how to answer that. I an not an experienced driver at all and have nothing to compare it to cause this is my only hydro ever. I'll try to get you a video this week with the same setup. Maybe you can look at it and give me some advice.
                Thanks,
                Alvin
                • jingalls007
                  • 1015
                  Thanks,
                  Alvin
                  Im also new to Hydros so perhaps the blind leading the blind I was curious to know how that prop handled the turns and excelled out of the turns. My m440 was a great prop in the straights, not so much coming out of the turns. My L38X55 however was great for both but temps were higher. I was just curious if you had noticed any of the above with your 537/3 or your 437/3.
                    • 9479
                    Jingalls, I have tried a 437/3 and liked it a bit more than the m440..
                    I still need to try a L38x55 but you say your temps were a bit higher..
                    • Rumdog
                      • 6453
                      how the hell did you burn up an etti 150 in a ul-1?!?!
                      • jingalls007
                        • 1015
                        temps were higher in the 38X55 but still not hot enough to burn anything up. I ran for 10 minutes as i do all of my runs.
                        • alvinsmith75
                          • 635
                          I am pretty sure I had a short somewhere. Be careful of the Etti's I believe it was the wire going to the receiver. From the factory it it tie strapped to the battery wire and runs between the caps. The wire was burnt in that area, I should have caught it but didn't. Steven and Etti have great support. The esc and extra cap board were replaced in about 3 weeks.
                          • alvinsmith75
                            • 635
                            Alvin,
                            Video with y537/3 I am not an experienced driver but this prop is fast and fun 47mph.
                            • alvinsmith75
                              • 635
                              Ran this morning with a x437/3. It was far too windy to give a fair comparison but I can say this. On GPS it ran 42.1 and I ran for 8 minutes and still had battery to burn. Even when it is calm the boat wobbles side to side in long straights. How should I adjust my rudder and turn fin to help?
                              Thanks,
                              Alvin
                              • detox
                                • 2310
                                First I would lower the strut to 1 1/8" - 1 3/16". Then turnfin should be angled UPWARD slightly against setup board edge (hull resting on sponsons and bottom of strut). Can you turn your lipos cross ways? This will move COG more forward. I like the Grimracer L40 x 57/3 prop best, but it is a little tricky to sharpen and balance. While sharpening prop I wear a cheap pair of strong reading glasses ($5.00 @ Walmart) to help see LOTS better. You should see 49mph with the above setup and boat will also be a little more stable. IMO air dam is not needed at these speeds.
