UL-1 Eagle Tree data with Grimracer L40x57 3 blade prop
  • LuckyDuc
    Team Ducati Racing
    • Dec 2008
    • 1058
    Originally posted by Drag Boat Bob View Post
    LuckyDuc,
    Does the ESC still provide input voltage to the BEC or are you using and external source?
    There is a positive and negative lead coming off of the BEC than gets soldered onto the ESC's battery leads. The ESC's receiver wire is then plugged into the BEC, and then the BEC is plugged into the receiver's ESC channel.
    • LuckyDuc
      Team Ducati Racing
      • Dec 2008
      • 1058
      Data for the Grimracer L42 x 66 is now available. Link
      • LuckyDuc
        Team Ducati Racing
        • Dec 2008
        • 1058
        I put the Grimracer L40x57x3 back on yesterday and started tweaking my setup. After reading that Detox had his strut set at 1 1/8" I did the same. Bam! She gets right up on plane now. Thanks Detox!
        It is SUPER consistent lap to lap and very stable. I’m averaging 40mph now! Check out how consistent it is in the chart.
        I also hit 52mph with it on my second run.
        • detox
          • 2357
          You can see on the graph batteries are dropping off and boat is slowing. The new G3 batteries advertise flat consistant discharge before hitting LVC stutter.
          • LuckyDuc
            Team Ducati Racing
            • Dec 2008
            • 1058
            #35
            Here is a chart of the same run with speed AND pack voltage. The lowest voltage my packs hit under load was 14.33 volts. That is pretty good considering the amp draw on this power system.
            All packs loose voltage during use. I'm sure that the G3s have a curve similar to the one in the chart below... it just may have less voltage loss... Hard to say with out testing them.
            BTW. I've been running 3 x 4s 2250mAh packs in parallel for a total of 6750mAhs, and a continuous discharge capability of 135amps for the last 2 weeks.
            I should have mentioned that sooner in the spirit of full disclosure I guess
            • LuckyDuc
              Team Ducati Racing
              • Dec 2008
              • 1058
              #36
              Pic of my battery layout and mess of wires
              Also, the parallel connector I made with 12 guage wire, 5.5mm bullet connectors. This connector stays perfectly cool BTW. The hot temps are coming from the ESC side.
              • jingalls007
                • 1172
                #37
                Duc, is the stock controller in there somewhere?
                • LuckyDuc
                  Team Ducati Racing
                  • Dec 2008
                  • 1058
                  #38
                  LMAO!!!
                  Yeah. It's under the rat's nest... just follow the cooling tubes
                  • detox
                    • 2357
                    #39
                    LuckyDuc, What is the weight of your ready to run UL-1?
                    • Capt. Crash
                      • Jan 2009
                      • 341
                      #40
                      Very interesting....
                      ...that was a 10 lap run right?
                      Those are very similar results to my runs except I have to pull a full rudder 180 turn at one end of my course that really scrubs off the speed and tortures the turn fin.
                      Interesting that you are finding more speed at 1 1/8" and I'm going the other way and finding mine at 14-15/16". Must be a difference in the strut angle of attack? I would rather be at your setting because it's a lot easier to get hooked up.
                      Anyone tried de-tonguing this prop yet?
                      • LuckyDuc
                        Team Ducati Racing
                        • Dec 2008
                        • 1058
                        #41
                        6lbs 2.6oz (98.6oz)
                        For you metric guys... 2.796 kilograms
                        She looks light as a feather on the water
                        • LuckyDuc
                          Team Ducati Racing
                          • Dec 2008
                          • 1058
                          #42
                          Yes. 10 laps.
                          Most likely... I am getting more speed than you at 1 1/8" because I have 6750mAhs backing up the voltage.
                          • Capt. Crash
                            • Jan 2009
                            • 341
                            #43
                            Originally posted by LuckyDuc View Post
                            Yes. 10 laps.
                            Rip...that is what I was thinking too...but the specs on the MaxAmp 5250 is pretty impressive.
                            # 45mm X 138mm X 18mm
                            # 30C Constant(157.5 amps)
                            # 60C Burst - 2330 surge watts(315 amps)
                            # 241 grams
                            # Water-sealed for all-weather protection
                            # Comes standard with Hyperion taps
                            # Comes standard with 12awg Deans Ultra wire
                            # Highest performance in the industry
                            I think my prop sharpening skills may have something to do with it too!
                              • 9481
                              #44
                              What batteries are you running?
                              • Capt. Crash
                                • Jan 2009
                                • 341
                                #45
                                a pair of the above Maxamp 5250s.
