Be carefull...my detunged x645 killed my ESC.
My Eagle Tree data with m445
Ok, I think I know what the 1" at the strut means, but what or how do you get the 2* prop angle?Originally posted by LuckyDuc View PostThe strut is at 1" and the prop is angled down at 2 degrees. Batteries are all the way forward.
Lowering the strut will usaully put the needed angle on the strut. Using a setup board you should see light under the front edge of strut. 030" clearance will work. Some have used more in the UL1 with good results . You just have to testOriginally posted by Brushless55 View PostOk, I think I know what the 1" at the strut means, but what or how do you get the 2* prop angle?
Does lowering the strut loosen the boat up?.NAMBA20...Caterpillar UL-1, P-Spec OM29, P-Mono DF33, P-Spec JAE, Aussie 33" Hydro-LSH, Sprintcat CC2028 on 8s, PT SS45 Q Hydro, PS295 UL-1 power, OSE Brothers Outlaw QMono 4-sale, Rio 51z CC2028 on 8s
Does your cool Eagle show RPM ?Originally posted by LuckyDuc View PostHere is the last chart I'm doing with the m445 before switching to a Grim L40x57 for testing. Hit 52mph in the straights.
Check out Temp B. That is the ESC's Deans Connector!
But under a load would be different....NAMBA20...Caterpillar UL-1, P-Spec OM29, P-Mono DF33, P-Spec JAE, Aussie 33" Hydro-LSH, Sprintcat CC2028 on 8s, PT SS45 Q Hydro, PS295 UL-1 power, OSE Brothers Outlaw QMono 4-sale, Rio 51z CC2028 on 8s
Yes voltage does drop under load, but you cannot just multiply volts (4s) times kv to get your top rpm under a load...Originally posted by LuckyDuc View PostIt wouldn't be as far off as you think because voltage drops as well when load is applied.
I have a 60 size Cap 232 with a 500kv motor.. On 6s it will spin well over 11k free, but with a 16x8 prop my rpm is around 8k..
So by your math I'm only at 16v but in reality my batteries only drop about 1.5v..
