I know there have been quite a few issues with this hull but I haven't heard of anyone having an issue with the ESC arming. Suggestions? thx
Ul-1 ESC won't arm, no beeps.
Tags: None
I tried everything, including the TH. Trim adjustment, that I read in a earlier thread about a few arming issue's with the ESC. I have brand new maxamps 5250 30C but don't think that could be the issue??
Will do Skibo, thanks. I do have an "old" Castle barricuda 125 ESC that isn't water cooled, what are your thoughts on using this until my replacement ESC comes in and how long did it take to get your new ESC? thx
I am not very familiar with the Baracuda ESC but, if it has a built in BEC circuit that can handle 14.8 volts, or if you can hook up a 6 volt power supply to the receiver it should work. If the Baracuda has a BEC circuit but it can't handle 14.8 volts, you would have to disable that one before hooking up the external 6 volt supply. However, if you call Hobby Services tomorrow they should be able to get you one within 4 or 5 days. I live in Florida and I called on a Friday and received it the following Wednesday. Hobby Services number is 217-398-0007.Originally posted by jingalls007 View PostWill do Skibo, thanks. I do have an "old" Castle barricuda 125 ESC that isn't water cooled, what are your thoughts on using this until my replacement ESC comes in and how long did it take to get your new ESC? thx
Have only run it twice since I got the new ESC but both times ran like a dream. Hope you get yours fixed and get to enjoy it soon. Just remember to look at all the other threads about the UL-1 and make the appropriate upgrades. Have done most of them to mine also.Originally posted by jingalls007 View PostGreat, thanks so much for the help Skibo, I appreciate it. How's your Ul-1 running now?
You got lucky with Hobby Services and the time it took them to ship you your new ESC. They recognized the issue with the ESC but are now giving me the run around as to when they will ship it to me. I was told three different shipping dates on three different days but it is what it is I guess. I've used this down time to do the mods to make my Ul-1 rock solid, can't wait to run this boat. Thanks again for your help Skibo!Originally posted by skibo2 View PostI am not very familiar with the Baracuda ESC but, if it has a built in BEC circuit that can handle 14.8 volts, or if you can hook up a 6 volt power supply to the receiver it should work. If the Baracuda has a BEC circuit but it can't handle 14.8 volts, you would have to disable that one before hooking up the external 6 volt supply. However, if you call Hobby Services tomorrow they should be able to get you one within 4 or 5 days. I live in Florida and I called on a Friday and received it the following Wednesday. Hobby Services number is 217-398-0007.
do any of you know about the claimed lipo cut off with this ul-1 esc? i know there is not one on the super-v esc but i wanted to use the ul-1 on 3 cells if possablesee my fleet
: http://forums.offshoreelectrics.com/...hp?albumid=294
ok, prob need to go with a SV insetead. i have an extra UL-1 controler but this is in a boat for my girlfriend and i want to start it off pretty mellow. DF 26" with AMMO 2300, i figured 3s1p at first till she can gain some throttle control, then step it up to 2s2psee my fleet
yeah i know, im building a delta 26" with an ammo and ul-1 esc to eventually run on 4 cells. another one of the guys at the pond built his wife a nitro tunnel and i want to get a "ladies" class started. what stinks is it is going to be a boat i allready have so i cant even take it over when my plan doesnt work. if nothing else it can sit on the rack with the rest of them and she cant compalin about all my boats because they will then be all of "our" boatssee my fleet
I had a problem with my esc not arming on my UL-1 I got yesterday, I switched the throttle reverse switch, and problem solved!.NAMBA20...Caterpillar UL-1, P-Spec OM29, P-Mono DF33, P-Spec JAE, Aussie 33" Hydro-LSH, Sprintcat CC2028 on 8s, PT SS45 Q Hydro, PS295 UL-1 power, OSE Brothers Outlaw QMono 4-sale, Rio 51z CC2028 on 8s
A boat for your girlfriend,? good luck!
