Grimracer prop
  • Luckystattoos
    • Dec 2008
    • 4
    Grimracer prop
    I know this has been gone over and over and I have read all the threads. I have set up my strut according to the reccomendations and then some. I cannot get the boat to plane. I can throw the stock prop on and bam its on its way....I am lost guys. I have the 3 blade grimracer that is reccomended for this boat...please help.
    Thanks
  • Ub Hauled
    • 3051
    what kinda adjustments did you make to the Grim prop once you have it installed?
    • Luckystattoos
      • Dec 2008
      • 4
      I have not done anything to the prop itself only to strut depth and angle.
      • Capt. Crash
        • Jan 2009
        • 341
        I have my 40x57/3 @ 1 1/16" top of table, to bottom of hull with the shaft strut sitting on the table. I also sharpened/balance the prop. I have to goose it full throttle from a dead start to get it up out of the water...you can't do it gradually.
        • detox
          • 2357
          Have fun sharpening that DULL prop. A dull prop will cavitate badly. My L40x57/3 prop was very dull from factory and difficult to sharpen perfectly.
          Look here:http://www.aquacraftmodels.com/acces...op-tuning.html
          • LuckyDuc
            Team Ducati Racing
            • Dec 2008
            • 1058
            I have to agree. I'm in the process of sharping one right now for testing. It is very DULL... rounded edge dull. I've spend quite a few hourse working an edge on it.
            • egneg
              • 4759
              I have to agree the props are dull, thick, and need a lot of work. They look nice out of the box but don't let that fool you into thinking they're ready to go. I use a 1" belt sander with 120 grit to start with on the face then a file to clean up the hub and trailing edge. Once that is done I start the finishing process with 220 wet/dry on the face to get the deep scratches out. Now I use 400 and then 600 on the whole prop. Remember to keep checking the balance after the initial thinning and sharpening.
              IMPBA 20481S D-12
              • jingalls007
                • 1172
                I've had the same issue, thick prop, hard to sharpen. stock prop works real nice!
                • LuckyDuc
                  Team Ducati Racing
                  • Dec 2008
                  • 1058
                  The stock prop does perform nicely, but they don't seem to last long. Mine threw a blade after 8 runs.
                  • LuckyDuc
                    Team Ducati Racing
                    • Dec 2008
                    • 1058
                    Progress after 4 hours of balancing and filing an edge. I still have some more work to do.
                      • 9481
                      Looks Good!
                      • longballlumber
                        • 3417
                        I just finished running my UL-1 for the first time and I had very good results with 42 X 55 (2 blade)
                        • LuckyDuc
                          Team Ducati Racing
                          • Dec 2008
                          • 1058
                          Glad to hear that the maiden went well. Are the Grimracer 2 blades any easy to sharpen than the 3 blade lifters?
                          • longballlumber
                            • 3417
                            I didn't have a GPS or a radiar gun, but the 42x55 was MUCH faster than the stock. Plus the boat handled pretty good with that prop. It was running a little loose for my liking as a heat racing setup. Right now my strut is 1" with no angle at all. I will end up putting about 1 degree of angle next.
                            I think so... Like you an many other have mentioned, it takes time. I royal screwed up a 40X57/3 yesterday by trying to get into a hurry.
                            I have an M440 that I would like to try, but it needs to be S/B'ed to.
                            • detox
                              • 2357
                              My Grimracer L38 x 55 moves UL-1 faster than my Grimracer 42 x 55.
