Warning: Trying to access array offset on null in phar://.../vb/vb.phar/bbcode/url.php on line 2 Warning: Trying to access array offset on null in phar://.../vb/vb.phar/bbcode/url.php on line 2 Warning: Trying to access array offset on null in phar://.../vb/vb.phar/bbcode/url.php on line 2 Smoke? - RcBoaters Forum
Smoke?
  • MarkJnK
    • 26
    #31
    Originally posted by sailr View Post
    Rounded rudder
    Can you explain this a bit more? So the flat bottom of the rudder (which provides some lift I've read) is hindering the speed? Do you have a pic of the rounded rudder?
    • sailr
      • 7128
      #32
      You are basically correct. NOT a smart a$$ question...really!
      It had to be proven to me through actually comparison of larger mAh batteries to lower mAh batteries. I can't give you the exacto mundo scientific explanation nor am I interested in it. All I know (by proving it) that more amps SHOVE the volts through more quickly, forcefully, and efficiently...or allow more amps to be delivered to the ESC/Motor, thus more power because VOLTS X AMPS = WATTS/
      Trust me. (yeah, I know...about the bridge in brooklyn, etc.) Prove it to yourself. It really does work!
      Originally posted by MarkJnK View Post
      What did I miss here? I thought that voltage=power, while the mAH=size of fuel tank? How does mAH provide more power?
      p.s. I'm not trying to be a smart ass, I'm honestly curious and want to learn.
      Mini Cat Racing USA
      www.minicatracingusa.com
        • 9481
        #33
        Thanks sailr..
        I got a good deal on tower, not as good as you ! ah
        Hey what do you think about the Carbon Graupner 3 blade props?
        http://www.offshoreelectrics.com/pro...od=grp-2299.39
        http://www.offshoreelectrics.com/pro...od=grp-2299.42
        • sailr
          • 7128
          #34
          The carbon props don't seem to hold up. Too much power. I've seen posts of people throwing blades on them.
          Thanks sailr..
          Mini Cat Racing USA
            • 9481
            #35
            Nuts!
            they look cool and cheaper..
            • sailr
              • 7128
              #36
              Sorry, don't have any pics. I'll try to get some this weekend. I have read in many different places, including at least on UL-1 thread in one of the forums that the rudder bottom and leading edge should be rounded. I think it is to kill the lift that the flat bottom can create but don't quote me on that.
              Mini Cat Racing USA
              • sailr
                • 7128
                #37
                Yeah, that's why AQ boats come with plastic props. They KNOW you'll be back to buy the expensive metal ones!
                Nuts!
                Mini Cat Racing USA
                  • 7512
                  #38
                  Nuts!
                  Don't be so quick to discount the graupner K series. I use them quite a bit and have never thrown a blade. Use them to find the size that works best and then get a metal one if you want. They have held up well on everything from my SV to my DF 33 on 4s and 5s setups.
                    • 9481
                    #39
                    I still want to try them bro.
                    I like the looks of the 3 blade versions, just not sure what will work great.
                    • AndyKunz
                      • Sep 2008
                      • 1444
                      #40
                      The lower resistance in the larger cells allows more voltage to get to the motor.
                      mAH = milli Amp Hour - it's a rating of battery capacity (fuel tank size). It means that the battery can supply X milli Amps for one hour, or 1 milli Amp for X hours (roughly).
                      A milliAmp is 1/1000th of an amp. A 4000mAH cell can provide 4 amps for one hour.
                      Andy
                      Spektrum Development Team
                      • sailr
                        • 7128
                        #41
                        Good to know! The trick is finding the ones that will fit directly on a 3/16" shaft with drive dog and not screw-ons. Which ones have you used that worked good for you? I run a DF33 on 4S also in addition to the UL-1.
                        Thanks for the tip!
                        Mini Cat Racing USA
                        • sailr
                          • 7128
                          #42
                          Thanks Andy! Now I can sound more intelligent next time somebody asks!
                          Andy
                          Mini Cat Racing USA
                            • 7512
                            #43
                            Thanks for the tip!
                            Its not that tricky to find;
                            http://www.offshoreelectrics.com/products.php?cat=58
                            http://www.offshoreelectrics.com/products.php?cat=59
                            I am currently running a K54mm on my DF and a K48mm on my SV. Ran the DF yesterday in about 3 inches of chop and the prop was in and out of the water quite a bit. No problems with the blades when going from fully unloaded (air borne) to fully loaded (in the water).
