How to remove anodizing from hardware
  • longballlumber
    • 3417
    Has anyone tried to remove the black anodizing yet? I know there are certian chemicals that will remove it, but it can also pit the aluminum. I might try sand blasting too. Anyone else have better suggestions?
  • Meniscus
    Refuse the box exists!
    • 3312
    Longballlumber, here is one of the more recent discussions related to your question:
    http://forums.offshoreelectrics.com/...ead.php?t=6440
    • longballlumber
      • 3417
      Thanks,
      I should have done a search before posting...
      • Meniscus
        • 3312
        No problem, we all do it! At least I know I do!
        • EATMYWAKE
          certified dumbass
          • Feb 2009
          • 30
          sand blast it and wet sand what ever you were guna remove the anodizing from. go from 400-600-800-1000-1500-2000 grit and after the 2000 grit use mothers aluminum polish. it should look almost like chrome if not the same, after your done... otherwise, the easy off should work....
          • Meniscus
            • 3312
            • egneg
              • 4759
              Sodium Hydroxide (draino) will work but the water needs to be 160 degrees for best results. Put a table spoon in a shallow non aluminum or glass pan and stir - the parts need to be moved around to keep fresh chemicals in contact with the surface. After a few minutes check the parts - when done they will be a dull grey and ready for polishing.
              WARNING!!!: this is harsh stuff and rubber gloves and goggles are required. Also this needs to be done in a well ventilated area as the gas given off is very nasty!
              IMPBA 20481S D-12
              • Meniscus
                • 3312
                So you do have a hot plate in the garage!
