will this lipo work for the ul-1???
  • killjoy781
    • Jan 2009
    • 45
    sup people,,,newbster here,,,
    im planning on getting this hydro and was wondering if the following would do the job well......
    Spec. Capacity: 5000mAh Voltage: 4S1P / 4 Cell / 14.8v Discharge: 30C Constant / 40C Burst Weight: 520g (including wire, plug & shrink wrap) Dimensions: 140x48x33mm Balance Plug: JST-XH Discharge Plug: Bullet Connector 81.0 KB ยท Views: 3
    thanx!!
  • detox
    • 2357
    It will barely fit and will work, but the UL-1 calls for two 2s packs (4s total). You will also have to change the connectors to use that pack.
    • killjoy781
      • Jan 2009
      • 45
      well, im just trying to stay on a budget. these packs are beutifully expensive..
      i found that sideways, the battery should fit snug.
      but i dont know if it will flush with the tub..the following are the specs of the aquacraft ul-1 motor mount.
      SPECS:
      Length: 146mm (5.7")
      Width: 38mm (1.5")
      Height: 20mm (0.79")
      and this is the dimension for the battery.
      think itll be too tight?
      • mike martin
        • 357
        I have seen guys run a 4s pack insted of 2 2s packs but the boat doesn,t seem to handle as well the 4s you have to put sideways close to the motor and just that little bit of weight not being forward the boat did not handle as well. maybe if you added a little weight in front of the batt?
        • killjoy781
          • Jan 2009
          • 45
          yeah thats another thing i was thinking about...
          i found that it will be cheaper for me to buy 2x4s1p 2200mah 20c
          rather than 1x4s1p 5000mah 20c.
          what im tryin to find out, is if the 4s1p 2200mah 20c lipo will fit
          Dimensions: 101x35x33.2mm
