UL-1 first observations
  • Flying Scotsman
    Fast Electric Adict!
    • 5190
    For a RTR boat very impressive out of the box
    There were some minor problems...as properchopper advised me of..check the powertrain allignment...mine was off...check all fasteners...check the water jacket..mine was ok.
    A minor crack in the fibreglass at the stuffing tube entry point into the hull.
    Check rudder position in neutral position...mine was off.
    I am amazed at the overall quality and fiinish at this price level.
    I will paint the plastic white hull cover as it looks plastic and cheap.
    So far a 7 out of 10.
    Edit update
    After reassembly the water jacket which was not removed and was given an air check now leaks badly with a water test at arround 50psi
    Douggie
  • Darin Jordan
    • 8332
    Douggie,
    When you say it's "off", are you talking about after firing it up??
    When I disassembled mine, I took the pin out of the rudder to get the steering arm off (not a trivial task... which is good for racing... one less thing to worry about falling off! )... The pin has flats in it for the set screws on the rudder and the steering arm, and they are NOT at 90-degrees to each other... So when everything is tightened down, the steering are will not be at a 90-degree angle to the rudder...
    Still works fine, however...
    Darin E. Jordan - Renton, WA
    • Flying Scotsman
      • 5190
      Darin, you are correct as to off
      Douggie
      • Darin Jordan
        • 8332
        Douggie
        Just live with it then... I don't think there is anyway to correct that short of replacing the hinge-pin... I'll get some shots tonight to post of mine so you can see what I'm referring to...
        Not a big deal, really... Just looks a little off...
        • Capt. Crash
          • Jan 2009
          • 301
          Douggie
          Ok...how do I do this...what do I look for...how do I correct?
            • 7990
            The flex cable should slide right into the coupler as you feed it through the stuffing tube. If you adjust the strut much this will throw the motor/cable alignment out. I was able to bend the tube down a slight amount to bring it back into alignment with the coupler.
            • Flying Scotsman
              • 5190
              Captain Crash from the prop to the motor the shaft should be in line with each other and allow you to push the flex/wire shaft into the motor connector with no binding.
              Douggie
              • Flying Scotsman
                • 5190
                Jay, your answer is much better than my feeble attempt.
                Also, I will try Jay's resolution to the water jacket problem. As found in my edit
                Douggie
                • detox
                  • 2310
                  I received my replacement water jacket from Aquacraft. The new end caps and housing have that same sloppy loose fit at the threads as before.
                  • Capt. Crash
                    • Jan 2009
                    • 301
                    Thanks...I had a bear getting that cable into the coupler last night...I thought it was the motor shaft being misaligned after I added a thrust bearing and remounted the motor. I will look at the stuffing tube tonight.
                    BTW...the motor mount bolts have very fine threads and strip out pretty easy...trust me...I know!
                    Crash
                    • Darin Jordan
                      • 8332
                      Crash
                      Are you referring to the mounts where they bold to the hull, or the mount to the motor??
                      • killjoy781
                        • Jan 2009
                        • 43
                        should i not get the ul-1?
                        lol you guys are startin ta scare me.
                        • Capt. Crash
                          • Jan 2009
                          • 301
                          The motor casing. I turned the starboard one a little too far....now I have the magic blue liquid on the threads.
                          • Flying Scotsman
                            • 5190
                            Killjoy. I trust that you enjoy your UL-1. As many FE boaters are very excited with this RTR model. What boats do you presently own and what is your RC experience...just currious?
                            Douggie
                            • killjoy781
                              • Jan 2009
                              • 43
                              Douggie
                              i know,,,,im excited toooo! I CURRENTLY DO NOT OWN A BOAT...
                              *3 years racing & building rc cars (nitro)
                              *6mnths flying helis (electric)
                              *1 year miss elam (nitro) sucked because it had a 15 dynamite
                              *4 years ww2 planes (electric)
                              *2 years EDF
                              AND NOW IM READY FOR MY UL-1
                              I MUST ASK:::: WHAT ARE THE UPS AND DOWNS ABOUT THIS MODEL?
                              AM I ABLE TO USE A PAIR OF 2200MAH 20C's?
