Tactic 2.4 radio mod info for 100% rev throttle
  • SweetZ28
    • 1535
    Hi guy's this was asked on another board so i thought i would post it here for you guy's because the tactic radio the way it coms it don't have no way near 100% reverse throw travel on the trigger so here's a simple mod i did to give the radio 100% reverse also.
    May want to keep this tacked up top in the board for further use.
    Ok i tested the Tactic and it don't have 100% reverse...I tested it on my ESC as the new Tactic when installed in my slash in reverse the esc's full reverse light did not come on...so here is a mod i did to make the reverse throw on the trigger the normal 100% throw.
    Hope this helps everyone.
    WWW.PPRSLOTS.COM
  • Ub Hauled
    • 3051
    Usually on boats we don't use reverse at 100%,
    actually, it should not be done so... one can sink the boat.
    My advice is, if you must have reverse, setup enough just to get outta trouble,
    up to 50%.
    • SweetZ28
      • 1535
      up to 50%.
      Why not push reverse only a little back?
      Also You can always do the mod and if you want less reverse slip a piece of silicone fuel line over the trigger so it won't push as far in reverse when using in a boat but lot's of guy's will be using these with there boats and other RC cars to this is why i posted the mod.
      WWW.PPRSLOTS.COM
