Avoiding Problems with the UL-1 Hydro
    • 7990
    Now that a few UL-1s have been on the water we can identify areas to watch. Several owners have found that their motor cooling jacket leaked. I moved my jacket before I tested it for leaks so it may have arrived fine - but after I adjusted it, blowing into one of the inlet tubes showed a leak at the jacket threads. Yours may or may not leak, be certain to check before you run the hydro. Here is how I easily fixed it:
    - Remove the motor from the hull and unplug the wires and water lines.
    - Shoot some WD-40 or similar lube into the inlet tube, enough to coat all the motor housing that's inside the jacket. Don't be stingy.
    - Loosen the end rings no more than two turns and put a thin oil on the threads where they enter the end rings.
    - Tighten the end rings by hand until tight. Make certain that the water inlets are positioned correctly.
    - Wipe off any oil from the motor and jacket.
    - Check for leaks by blowing into one of the inlets with the other inlet plugged. There should be no sound of air passing by the threads.
    - Reinstall the motor, wiring and cooling lines.
    The small rear winglets are held on with a thin strip of double sided tape. When mine arrived they were also held down with strips of regular clear tape, but I removed those. That made the winglets too easy to remove or to come off on the water. I suggest leaving the outside factory tape in place and forgetting about them.
    Most of the fasteners (maybe all of them) are metric, so heed the instructions and be sure to have the correct metric tools - especially allen wrenches - available. Stripping out a socket head machine screw by using the wrong wrench is not a pretty thing.
    I'm still very impressed with the UL-1. Like any new product there are minor issues to iron out, but by sharing that information we can maximize everyone's enjoyment with this fun little boat.
  • JimClark
    • 5902
    If those O rings are silicone the WD-40 may soften them. I know I used WD-40 to install the Gundert Silicone water jackets and ruined two of them.
    Jim
    Billy Graham
    • H&MWill
      • 623
      Jim
      Soapy water works good and is safe for Orings.
      Many issues!!!
        • 7277
        Plain old dish soap is a great lubricant for installing cooling jackets. A thin bead of silicone around both ends of the cooling jacket WILL solve any leak issues.
        • egneg
          • 4664
          I use a few tricks from airbrushing that I and other airbrusher's have been using for many years.
          One is to use Glycerin to lube the o-rings for ease of installation (also great for putting on water tubing). It is water soluble though so it can't be used as a sealant just an aid in getting the water jacket and tubing on. The other is to use bees wax to seal the threads. Soften it by warming it up and use a small amount on the mail threads before assembly. Both are perfectly safe to use and will not harm any parts.
          IMPBA 20481S D-12
            • 7990
            Relax. The instructions state to use WD-40 to flush out the cooling system - WD-40 is perfectly safe.
            • JimClark
              • 5902
              I wasn't all stressed about it Jay. At least not about that.
              Jim
              Billy Graham
                • 7990
                NOT if the leak is past the threads on the jacket, which it was.
                • Eyekandyboats
                  • 1921
                  thats what she said... LOL!!!!
                  i am sorry back to topic
                  EYEKANDYGRAPHICS
                  www.rclipos.com
                  • sewerpit
                    • 117
                    fluid, what batteries are you using in your boat
                    • Grimracer
                      • 656
                      Jay..
                      Here is how i hold my wings on..
                      Clean off all the old tape.
                      Lay down some radio box tape (Sorry its got to be Grimracer for this job) over the recess pocket for the wing.
                      Using black two sided tape (the RC car stuff) place a full amount under the wing.. Stick the wing to the tape that is covering the pocket..
                      Done..
                      If the wings get hit.. no hole in the boat..
                      Gim
                        • 7990
                        I run two, 2S1P 5000mAh ThunderPower V2 cells. In series of course.
                        Mike:
                        I'm sure that works fine and thanks for the suggestion. Frankly I'm not a fan of wings anyway so I'll just leave them off my boat. That will also make it easier to identify my hull in a heat with five other UL-1s!
                        • Steven Vaccaro
                          Administrator
                          • 8724
                          Unless any future rules changes say that you need them on there....
                          Steven Vaccaro
                          • Treydog
                            • Dec 2008
                            • 12
                            Guys, just got a UL-1 Superior and the boat flies man! Still a noob here and I also got a Proboat Brushless Miss Elam a few weeks ago. My dad was driving the Elam and I was driving the UL-1. Didn't seem to have any problems with the radio frequencies but i guess later we did. Anyways, somehow I didn't turn sharp enough and the boat ended up banking itself while trying to turn. So I jump in the golf cart to get over there too it and when i got there the boat was running full throttle and water shooting up from the bank like a fountain. Yes, the propr was still somewhat in the water. So I pulled all the hockeytape off and immediately disconnected the lipos. Propr was still running wide open while i am doing this so it was a bit scary. Didn't seem to have had any damage except for a few chips taken off the plastic prop. No worries there since i also bought the hop-up prop when i bought the boat. Nonetheless, I took the boat home, cleaned her up, and recaharged the lipos. Now I am trying to restart the boat but the ESC or motor just keeps beeping - not giving me a chance to arm it. How do I fix this or is my ESC or motor shot? Nothing felt really hot when I got there after the accident so I wouldn't think anything was blown...I can steer the servos but I cannot get it to stop beeping or for the throttle to spin the prop at all. FYI, the servo is plugged into the CH 1 Slot and the ESC is plugged into the CH 2 slot inside the boat. Please help. Thanks so much!
                            Treydog.
                            • Grimracer
                              • 656
                              Jay.. yea wings on a sport hydro or any full body hydro can be a bummer.. The system I designed is baced on my Sport 40.. I designed tape on wings for it and they have saved the boat from sure deck death a few times.
                              Grim
