UL-1 motor upgrade
  • Jlov
    • Nov 2013
    • 825
    Yes I will Siberian. Ive bought the motor but its coming from Europe so will be about 10 days to get here. Im going to upgrade ESC to a Castle 180 or Turnigy 180 while I wait for motor to come. Once I get them I will be looking to sell the stock motor and ESC. I will let you know! Thx Jeff
    • Jlov
      • Nov 2013
      • 825
      And Shovelnose based on your post I can run this new Leopard 4074 on 2S? I thought I read that the motor needs 3S and up lipos? Thx Jeff
      • blowNover
        Flounder
        • Nov 2012
        • 193
        Once again yes Siberian the hull starts the walk of death at high speed but once modefied that problem is fixable(to an extent). Comparing it to a whip or even an fe30 is just unfair. As far as packs I run two 4s 3200mah packs. As said before it will completely submarine on initial launch then it catapults out of the water and plains very quickly. To answer your questions I wouldn't run any 40mm can on anything less then a 120amp esc. As far as packs if the 2s are high enough c rated it's ok but it would be safer on 4s2p.
        • Heaving Earth
          • 1929
          where will a t180 fit under that cowl?
          • Heaving Earth
            • 1929
            a leo 3674 2200kv and t120 would have done the trick. the 40mm can isn't gaining you any speed, just more power consumption, and a larger esc needed. oh well….
            • blowNover
              Flounder
              • Nov 2012
              • 193
              I can understand the disbelief. It was a real pain to make work. But here's a pick before the caps went poof and deformed the cowl a little over them.
              • Jlov
                • Nov 2013
                • 825
                Yea Heaving I hear ya. But I got that motor brand new with jacket for $50 and just got on here today a brand new Swordfish 200 with program card for $75. So Ill have only $125 in the whole setup. Im not racing just running this in the canal behind my house. Which reminds me to ask is there anything I should do differently since Im running in saltwater? I use corrosion X and lube shaft after every run. Thx Jeff
                • olwarbirds
                  Magic Smoke Wizard
                  • Oct 2012
                  • 1194
                  I see...got another UL-1...
                  • olwarbirds
                    Magic Smoke Wizard
                    • Oct 2012
                    • 1194
                    saltwater = corrosion
