UL1 Brass Prop upgrade - Won't Plane ??
  • mopwr
    • Jul 2013
    • 3
    Hi everyone I purchased a brass prop upgrade that is recommended by Aquacraft - Brass prop 9760 - The boat won't plane with the prop....installed the stock prop and the boat planes a moves really good .....What am I doing wrong ?...Shows that this is an high performance upgrade.
    Thanks
  • Heaving Earth
    • 1929
    It needs to be balanced and sharpened. If its the L40/57/3 blade, then yes, definitely doesn't plane unless the balance and sharpening is done. those props are quite difficult to do too
    • Heaving Earth
      • 1929
      If its done right, you'll see 50mph with that prop
      • mopwr
        • Jul 2013
        • 3
        Thanks for the advice ....I am using the stock one for now but will see what I need to do for balance/ sharpened process ....
        Thanks again
        • MR2NR
          Jet Stream EP
          • Sep 2011
          • 160
          Have you tried lowering the strut?
          Kyosho K.I.T.T.
          • mopwr
            • Jul 2013
            • 3
            I did lower the strut and was a little better but not performing as it should .....Was told to sharpen and balance ....
            Thanks for the post !!
