New to theUL-1 and boating.
  • stelerzman
    • Jul 2013
    • 380
    Originally posted by SirBudman32 View Post
    No problem. You can wax the top and sides if you want just not the bottom. As for the servo hone mine is on the 3rd one from the screw, and about 1/4'" of throw maybe a little more but it does not take much.
    Nice, thanks. I'll check it out.
    • SirBudman32
      • Aug 2011
      • 701
      You can get a nice and straight piece of wood with some 500 grit sand paper and true them up if you want. Try to get a block that will cover both at the same time.
      Modified Jae21, Stock Jae21, Cheetah, Ul-1, Shock Wave 26 V2 (Rescue Boat).
      • stelerzman
        • Jul 2013
        • 380
        Cool, I'll do that. Any idea how thick the hull is in that area? I don't want to take too much off and make it a weak point.
        • SirBudman32
          • Aug 2011
          • 701
          not sure.
          • stelerzman
            • Jul 2013
            • 380
            I guess I'll just drill a hole in the bottom of both the sponsons and measure it, then repair it.
            • wayne middlemiss
              • Feb 2012
              • 47
              warning they are very thin would be best to use light ply and filler.
              • Heaving Earth
                • 1929
                Considering its a 3 point hydro, and the transom doesn't really ride in the water, what is the concern?
                • stelerzman
                  • Jul 2013
                  • 380
                  As you stated" a 3 piont hydro". Then why is it that most of the info I'm getting kinda goes away from this factor. Thank you HE, your the first to post this very important info. I've talked to several local 1:1 boat builders with a " BOAT " load of knowledge and they are the only ones to hit on this piont.
                  Major " PROPS " to you Bro.
                  • stelerzman
                    • Jul 2013
                    • 380
                    Another question, how accurate is this hull compared to a current 1:1 boat.
                    Also, any way to know the age of the boat I currently have??????
                    Thank you to everyone that has posted info for me to absorb and work with. You are all top notch people for helping the new guy. Major PROPS.
                    • stelerzman
                      • Jul 2013
                      • 380
                      Well, the weekend is almost here, I can't wait.
                      When I measure the strut depth, which is 7/8" to the bottom of the drive cable sleeve. Is this the correct place ?
                      Thanks.
                        • 7512
                        Probably not a bad place to start...but you will only find the true sweet spot once you run it and tinker with all the adjustments...remember, when you start tuning things, only do one thing at a time, that way if something works better (or worse) you will know what you did.
                          • 7512
                          As to the age of your boat, the first release had some issue with the turn fin mounting area not being strong enough and cracking, also the controller had smaller capacitors installed and sometimes failed.
                          Post a pic of the controller, that will help determine if you have the older version or the newer version of the UL-1 (assuming that the controller is the stock one that came with the boat originally, and wasn't swapped out)
                          • stelerzman
                            • Jul 2013
                            • 380
                            I
                            Ok, I'll leave it as is and see what happens. I've been in the RC world for about 5 years and quickly found out the importance of changing one thing at a time to see the difference. I've also learned that taking notes is very important. Come on weekend.
                            • stelerzman
                              • Jul 2013
                              • 380
                              I'll post pic's of the controller later tonight, if I remember correctly it has a small cap and a long cap. I don't know what what this means but hopefully pic's will conf
                              erm the age and wether or not it a moded old or newer version.
                              Thanks.
                              • stelerzman
                                • Jul 2013
                                • 380
                                Doby, you mentioned the turn fin mounting area, what about the fin itself? Should it be flat or curve under the boat? Mine s curved.
