New to theUL-1 and boating.
  • 4sdash
    • Sep 2013
    • 54
    #151
    stelerzman great thread i was wondering if you might be able to help me with my boat i got a use ul-1 it has an 1800kv motor and esc out of a spartan i run 4400 40c 2s bats all the way in the sponsons so the area in front of the motor has nothing there i have an 642 prop s\b on it now . the questions is im going to the grim 40/57/3 blade what should i make the strut hieght with this prop and how to get ride of chime walk it really bad boat get up on plane very fast and the boat really movers just unstable thanks for any help
    • stelerzman
      • Jul 2013
      • 380
      #152
      I have my strut up all the way, 7/8" from the hull. If you look back a page or two I posted a pic . I would like to see some pic's of your boat if possible.
      Do you have an air dam installed? That might help to stabilize the boat.
        Originally posted by stelerzman View Post
        Here is a video of a stock UL-1 prop, It's running aprox. 43mph. Once I get the boat tuned and setup correctly it should run a bit better.
        It's all a work in progress.
        http://www.youtube.com/watch?v=CUh49_-WZCE
        Looks good!
        • stelerzman
          • Jul 2013
          • 380
          #154
          Looks good!
          Thanks. I wanted to get some testing in today but when I relocated the motor wires I noticed a solder joint was coming loose so out the window with the test run. Oh well, next time.
          On another topic, I've decided to make a stronger and wider turn fin mount. I'm almost done measuring and drawing it out .
          I'll post up some pic's soon.
          • stelerzman
            • Jul 2013
            • 380
            #155
            Here are a few pics of my idea to make a stronger turn fin mount with out having to get into the hull.
            I'll cut the rough shape with a band saw then clean it up on a belt sander. I might even polish it up on my buffer to a mirror finish.
            I'll start this project asap.
            • Heaving Earth
              • 1929
              #156
              Is the stock turn fin mount not working or something?
              • SloHD
                Slow Electric Addict!
                • Apr 2013
                • 337
                #157
                I use a black ul1 fin on my elam and it's been great.
                I could wrong, but I think you might have it layed out backwards.
                  Are you still using the stock connectors on the motor and esc and deans on the cells ?
                  It would help the setup run better if you put 5.5 bullets on everything.
                    Hey.
                    Is't it the inside of the hull of the sponson the weak points for the stock turn fin and mount ?
                    And I know most members love the stock turn fin to use on high end Hydro's for racing.
                    • stelerzman
                      • Jul 2013
                      • 380
                      #160
                      It's not broken or anything, it's flimsy to me. I figured if I spread the load out it would make it more rigid.
                      • stelerzman
                        • Jul 2013
                        • 380
                        #161
                        More of an optical illusion. It is correct just so you know.
                        • stelerzman
                          • Jul 2013
                          • 380
                          #162
                          I am at the moment, but will be changing over soon.
                          Hey.
                          And I know most members love the stock turn fin to use on high end Hydrto's for racing.
                          The turn fin is fine, just need a better mount.
                          • stelerzman
                            • Jul 2013
                            • 380
                            #163
                            Good news, I took the boat out to day for more testing and tuning. I installed my own version of an air dam and I have to say not much different with or with out. I still have more testing to do and hopefully I'll come to appreciate the air dam.
                            I did run across a minor glitch in the cooling system, I found that some debris in the line after the esc, it was blocking the line which created more heat than normal. I cleared the line and made another run and all was much cooler.
                            I'm working on a couple videos to share with you so you can see where I'm at with the boat. I'll post the links when there ready.
                            • stelerzman
                              • Jul 2013
                              • 380
                              #164
                              Here is one of the videos.
                                Good to hear you found the block and part of your heat problems,
                                Try to stay out of the green stuff and muck it grows in or you may have more blockages.
                                You should pull the water jacket once in a while and look for sand and stuff like that in there to,
                                The boat looks to be running a lot better the way it should in that video.
