Good CG range
  • MR2NR
    Jet Stream EP
    • Sep 2011
    • 160
    Good CG range
    So I've about got the boat together and started with a bare hull. What is the best CG on these? First Hydro coming from mono. I know that 2/3ds toward the rear is good for monos but thinking Hydros want more in the center if not forward a hair for good sponsoon tracking. :). Also I would like to see weights of these and asking anyone with heavily modded boats what your wet weight is. (fully loaded with batteries.)
    I'm sitting at 5 Ibs. 3oz. right now. but need to finish some coolant line and S+B the prop
    Kyosho K.I.T.T.
    Hi.
    Have any pictures of your boat and setup inside of the hull ?
    How big is the boat and on what cells will you be running ?
    • MR2NR
      Jet Stream EP
      • Sep 2011
      • 160
      Hi.
      lol well It's a normal RTR UL-1 Dont really know if there is much of a variation size wise from revisions. I'll be running 4s. As soon as I get the cooling tubing done Ill post some pics.
      Kyosho K.I.T.T.
      • MR2NR
        Jet Stream EP
        • Sep 2011
        • 160
        Here's some pics...
        I also had to repair the left sponsoon and it was cracked in a few spots so i just sanded things down and epoxied some carbon on it.
        Same with the Transom.
        I am running two pickups as the tiny rudder one doesn't sit well with my motor size.
        ...and i know I am running too small of battery connections but I had a ton left over from the cars and when I am a little more better with finances I will upgrade to 5.5's, kinda why I screwed up the soldering job on the Y harness :)
        Kyosho K.I.T.T.
        • h2o 1
          • Sep 2011
          • 854
          COG on this hull should be an inch and a half to three inches behind the sponsons Matt.
          • dana
            • Mar 2010
            • 3660
            Run the batteries as far forward as possible. What motor is in there?
              I think it is a 3674 2200kv.
              But not sure on that.
              He said it was stock setup.
              • MR2NR
                Jet Stream EP
                • Sep 2011
                • 160
                Stock Hull but all the internals is aftermarket except the servo. Leopard 3674 2200K is correct. Using Gens Ace 2200 60c Batts 4S. They are in the pic :) Shoved as far forward and outboard as I have seen :). But ya run time will be around 15 min I'm guessing.
                Kyosho K.I.T.T.
                • G-UNIT
                  • 971
                  Just budding in here, I have the same set up with that motor running 4s 5000mah 40c-50c burst
                  with a m445 s&b, running in the 50 range but I don't belive you will get 15 min run time out of it, more like 4-5 min, but anyway run it for a few laps and check temps.
                  jmo, have fun.
                  • MR2NR
                    Jet Stream EP
                    • Sep 2011
                    • 160
                    How much time are yours getting? If things are that bad Ill just run 2s for fun and 4s to race. :) I also have some hardcase 40'c but cant get them in the hole :).
                    Kyosho K.I.T.T.
                    • G-UNIT
                      • 971
                      Like I said I'm getting about 4-5 min on 4s thats 2x2s to make 4s, I not sure but that motor won't perform on a single 2s.
                      I could be wrong, just never ran it or tryed it on 2s and only 7.4 volts it will be slow.
                      Everything I read in this site says most all fe boats run between 4-6 min.
                      if your getting 15 min run time thats great, but hard to believe on 2200 mah batterys.
                      • MR2NR
                        Jet Stream EP
                        • Sep 2011
                        • 160
                        Well on my mono I can get 30 min with 5000mahs so I was just halving it :). Ill bet you are right though with a hydro and bigger prop. I really like how these batts. fit though. I was thinking I could just by another pair and put them in parallel and double the Mah but I hate the way you have to splice solder. Would be cool if they made a 5.5 Y or T bullet or is there a better way ? Maybe stick a 5.5 in a 8 solder hole.
                        Kyosho K.I.T.T.
                        • G-UNIT
                          • 971
                          Are you running in series or paralelle ? spelling, you know what I mean.
                          Even on my impulse, still only getting around 4-5 min on 5000mah and when recharging them i'm putting 3800-4000mah back in.
                          you should leave about 20% of charge in the batterys.
                          • dana
                            • Mar 2010
                            • 3660
                            What kind of mono?
                            • MR2NR
                              Jet Stream EP
                              • Sep 2011
                              • 160
                              Both if I get two more packs. Parallel batts. Series to the ESC. so I would be at 4400mah with four 2200mah batts. I have 2 on board voltage meters on each batt. so I know where Ill be I heard that the ESC Im using isn't very reliable with voltage cutoffs so I am not relying on it :).
                              I mainly did this because i wanted the batts. to be as far outboard as possible and the hull came with a huge hole in the front so why cut it up any more :).
                              Dana I am referring to the Jet Stream in my avatar. It wasn't very fast though so Im taking that into account that as well.
                              I'm thinking now I will need the extra batts but of course I bought the last two HP had lol. I prob have the lightest UL-1 though right now lol. Might run it one or two passes and see where I'm at.
                              Kyosho K.I.T.T.
