Leo 3674 2200kv timing ?
  • G-UNIT
    • 971
    As the title asks what is the best timing for this motor on 4s?
    when I ran the UL-1 with 4s and the stock esc (60 amp) I hit 59 mph w/a m445.
    put in t120 and timng set at 15 d only hit 47 mph, nothing else changed.
    I can only think its the timing.
  • dana
    • Mar 2010
    • 3660
    15 degrees is rite. Turn your lvc down or off
    • G-UNIT
      • 971
      LVC is set @ 3.2
      I think last time is was set @ 3.0, but what does the lvc have to do with it?
      • dana
        • Mar 2010
        • 3660
        Try 3.0
        • G-UNIT
          • 971
          OK dana I'll try it and post the results, I do have a habit of listening to your advice.
          you the man!
          later.
          • dana
            • Mar 2010
            • 3660
            Haha cool man, try recalibrating too
            • G-UNIT
              • 971
              When you say recalabrating do you mean reprograming the esc, like resetting the esc for cell count, lvc, timing,ect. ect ?
              • martin
                • 2881
                That is a d wind motor set it to 3.75 on a t120.
                • clarkm
                  • Feb 2012
                  • 31
                  WOW! There is so much I don't understand about these motors and the settings that go with them.
                  I just purchased the 3674 1900kv for my UL-1, I have the swordfish 120a esc, what settings do you recommend to program?
                  • dana
                    • Mar 2010
                    • 3660
                    My bad, Martin is correct. I mistook it for y. Yes 3 degrees. Sorry dood
                    • martin
                      • 2881
                      The Leopard 3674 - 1900kv is also a d wind so around 3 degrees. With the t120, t180, SK 120 & SK 180 ( Turnigy & Seaking 120a & 180a esc are the same esc ) their are known problems with the lvc cutting in to soon, most set with no lvc at all but you must keep an eye on run times so as not to go to low on battery capacity ie leaving 20% capacity in the battery.
                      • clarkm
                        • Feb 2012
                        • 31
                        Thanks!!!
                        • G-UNIT
                          • 971
                          Ok so set the timing to 3 degrees and lvc to 3.0 on the 3674 2200kv leopard motor correct?
                          all you guys are the men, don't know what we would do without you fe brains because I know that I don't really understand all about the differ'ent wind configureations.
                          thank you all.
                          • dana
                            • Mar 2010
                            • 3660
                            Yes you're good to go now. Thankfully Martin jumped in to correct me lol.
                            Good luck man, let us know how it runs.
                            • G-UNIT
                              • 971
                              UPDATE,
                              Set the timing to 3 d and lvc to 3.0.
                              had a break in the weather and the lake was glass, the UL-1 ran a 55.5 mph and temps were good at about 112 on motor and esc and batterys were about 98.
                              what would happen if the timing was set to 0 degrees ? on that motor and I'm not even sure it can be because when recalabrating the esc with the tx it goes stright to two beeps, 3.75 degrees not just one beep for 0 degrees.
