Painting Help
I will wait for you to re open your Rio thread, then I can exchange some info with you, I am afraid the moderators will get up set if too much about Rio is posted here.
Bruce, I always liked how you painted your motor mount, it looks great! I wish my conversion was as neat and professional as yours, I simply pushed the BL in the stock mount, that is because I ordered the same mount after reading your original thread, but the mount is too wide for my purpose. Anyway, keep us posted, I know this is not the place to talk about Rio BL conversion.
Leave a comment:
I did clear over the top
made the paint come alive and smooth out the details
Leave a comment:
I think I did primer..Originally posted by clarkm View PostNice Job! Did you need a primer?
thank you!Originally posted by tlandauer View PostThe "fins" the original post refered to are the Vertical Fins ( stabilizers on the hull) I think it was unclear to the readers so it could be undersood as turn fins, it is interesting how much info canbe covered in two or three posts, love this forum!
BTW, Brushless55 , that paint is gorgeous!
Leave a comment:
Leave a comment:
Doubt they are aluminum but I used to work on and build sailboat masts of aluminum. There is an acid etch and then a alodine solution that seals the aluminum (stops it from oxidizing) then you can prime
Leave a comment:
I use KrylonOriginally posted by clarkm View PostWhat kind of paint will stick to cowl & Fins?
check out my Cat UL-1
Leave a comment:
Painting Help
What kind of paint will stick to cowl & Fins?Tags: None
Leave a comment:
