ul1 will not settle down now...
  • Rob DeAngelis
    • 296
    Had my ul1 running perfect... Got to close to the shore line and the prop hit a rock and obviously broke.. got a new prop (balanced it and sharpened it) re installed it and checked the strut to the same as it was... BOAT NOW RUNS WAY TO HI AND FLIPS AT FULL SPEED! cant even turn at half throttle without rolling it... tried lowering the strut more and it still does the same crap... wth
    Lakeside entertainer
    • 7512
    Whats the turn fin look like?
    • Rob DeAngelis
      • 296
      the turn fin was untouched... the rudder however was a little raised but not broken... I just readjusted it and made sure it was fine... the prop however took a good hit and bent two of the clevers... drive shaft and tube are good also...
      • Rob DeAngelis
        • 296
        No worries here, Im going to keep tinkering with it and install an air dam that I got from kintec and cross my fingures...
        • antslake
          RC nut
          • Nov 2010
          • 221
          Did you replace with the same prop?
          • Rob DeAngelis
            • 296
            yes
            • egneg
              • 4759
              Make sure that the strut is neutral along with being at the same height. Taking a hit like that I bet it's pushing the nose up.
              IMPBA 20481S D-12
