Making my ul-1 faster….
  • dana
    • Mar 2010
    • 3660
    ok so the hull got 48 consistantly on gps with stock stuff and 40/57/3. but now i want to upgrade a little and run 5s1p so im looking to upgrade motor, but i dont want a total power hog, because ill be running the 2s+3s packs. im thinking maybe the stock mc motor, a leopard 3674, or a feigao l or xl. so whose got some advise for me…. the hull is stock other than the air damn and a better motor mount. thanks
  • LarrysDrifter
    Big Booty Daddy
    • 3416
    I would think the Leopard 540XL 2200kv on 4s would get you to mid 50's easy. Thats what I want to try anyway. Maybe a 120amp speedo? A 180 would be ideal, but with the way the wires come out, it kind of screws you. I had a SF 200 in mine that fits much better. I ran my old UL-1 on 6s before, and it was too much for the hull.
    • G-UNIT
      • 971
      I've run the UL-1 quite a few times on 5s with no problems on stock motor and ESC, but I 'm sure it's just a matter before it goes up in smoke.
      I belive the motor will handle 5s but for safety I would upgrade the ESC to somthing that can handle 6s minimum.
      your doing great hitting your speeds with stock stuff and that prop, what are your settings, strut height,ect?
      • seaking ul-1
        • Aug 2011
        • 1
        I have the stock motor with a seaking 180 amp and i use 2 3s nano 22v and the motor run great!i got a grimracer blade 42-55
        • dana
          • Mar 2010
          • 3660
          no idea man lol i got the strut somewhere in the middle lol and uhm…. an air damn. i never really screw with it that much. the turn fin is level when the boat is sitting on the strut and sponsons. other than that, whats to tell?
          • dana
            • Mar 2010
            • 3660
            i can tell you i spent ALOT of time on that 40/57/3…. more than i ever have to spend on any octura prop. that thing is really rough and the blades are so damn thick, they really needed heavy filing and thinning.
            • Diesel6401
              Memento Vivere
              • 4391
              Only a matter of time before that motor blows. That 2030 motor is def not 6s motor. I would refer to this thread http://forums.offshoreelectrics.com/...ession-with-6s
              I would assume the amp load will soon be to much. Did you dis-able the bec on the esc? I always dis-able above 4s on all my esc's and run a rx pack. Once the hull gets into the mid 50s it just gets all over the place. I had my strut depth arond 1 1/8" if memory serves me right. Been a long time sense I had that boat. With the prices of Leopard motors if I had a chance to do it over i would try some new things on that boat.
              - Diesel's Youtube
              - Diesel's Fleet
              • G-UNIT
                • 971
                I'm thinking of putting a Feigao 12xl 1390 kv with a turnigy 120 esc in eather the UL-1 or in the impulse 31 down the road running
                5-6s this motor should have alot of torque to handle modded props ects.w'ell see, should be intresting.
                • dana
                  • Mar 2010
                  • 3660
                  im kinda stuck, i cant decide on running something in the 1800 kv range on 5s1p, or a leopard 2200kv and 4s2p. i wish i could make up my mind lol
                  • dana
                    • Mar 2010
                    • 3660
                    g-unit, have you tried the 12xl yet?
                    • dana
                      • Mar 2010
                      • 3660
                      IMG_0903.jpg here is what i did. changed the motor mount. believe it or not you can squeeze a 4074 in that mount with jacket. also those are 4 s packs and the cowl fits fine
                      • Diesel6401
                        Memento Vivere
                        • 4391
                        If you get a larger motor like the Leopard 4074 or Keda 4074 you can swing a larger prop. You could use a Leopard 4074 1800kv on 4s1p and swing a larger lifter prop like a L44x66 or L45x68 or you could use a higher kv Keda 2363kv motor on 4s2p and swing a L40x57 at a higher rpm or possible a L42x66. Then there's the 2000kv leopard or 2039kv keda that with a smaller prop you could get away with 4s1p. Just some options lol.
                        Sent from my T-Mobile G2 using Tapatalk
                        - Diesel's Youtube
                        - Diesel's Fleet
                        • dana
                          • Mar 2010
                          • 3660
                          lol thanks, options are whats driving me mad! that keda 2363 is looking pretty sweet. sucker would be heavy in front with everything. instant submarine lol
                          • detox
                            • 2357
                            I would use a higher spinning 2200kv motor and smaller prop (m440, L40x57, or x442). I used two 4s3300mah packs wired parallel (this helped add more weight). My UL-1 easily reached speeds over 50mph
                            The second picture with the purple fiegeo motor (1800kv) was slower using larger props.
                            • Gunny
                              Zombie Hunter
                              • Feb 2011
                              • 77
                              Here's a 58mph run
                              setup is
                              Medusa 2200 Motor
                              Seaking 180 esc
                              Upgraded Flex Shaft
                              Octura M645 Prop
                              2-2s 5000mah 40C Lipos
                              A bizarre incident in the outskirts of an American suburb. It was later revealed the disaster was caused by the T-Virus. A mutagentic toxin created by Umbrella Incorporated for use in bio-weapon experiments. Don't worry the zombies are looking for brains, you're safe.
